Posts: 3,345 |
So I topped up the fluid resevoir and as I expected, the noise is gone. When I get some spare time in the next few days, I'm going to get under the car and see exactly where the leak is. But right now, I'm not concerned.
EDIT: How did this thread end up in Duratec maintenance? I have a Zetec.
1996 MM
Zetec, ATX
192000 kms...not dead, but I'm not fixing it
White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
Posts: 980 |
Originally posted by Bullet: So I topped up the fluid resevoir and as I expected, the noise is gone. When I get some spare time in the next few days, I'm going to get under the car and see exactly where the leak is. But right now, I'm not concerned.
Who knows , but it's home now...
2000 Mystique LS
Duratec 2.5L MTX
Posts: 7,100 |
No clue how it got there...
but I moved it once I read that.. didn't have a clue you had a Zetec until then (maybe you should put it in your sig..)
Ray
'99 CSVT - Silver #222/276
Posts: 3,345 |
Originally posted by Ray: didn't have a clue you had a Zetec until then (maybe you should put it in your sig..)
Ray
Done.
1996 MM
Zetec, ATX
Posts: 7,100 |
I noticed that I accidently only moved the LAST post of your thread (yours) to Zetec... so.. I went ahead and moved the ENTIRE thread to Zetec, and quoted your last post (which I moved to this thread) in there, so that the entire gist of the topic could still be determined..
I hope you saw that, and I apologize.
Ray
Posts: 3,345 |
Yes I did see that, and no problem. It all works out.
1996 MM
Zetec, ATX
Posts: 1,224 |
Personally, mine is leaking from the front bearing on the PS pump. Dribbling down the side of my engine.  It also sounds like somebody is shaking a can of nuts and bolts.  BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
