Thanks Ray, I'll be sure to do that. Looks like tomorrow evening will be the night, as tonight I finished my 2000-to-pre-98 rear drivers door conversion
I have to say, if you get to the point of changing the wireing harness over and swapping glass, you've touched EVERYTHING in this door
ESC - that sounds about right. I'm assuming it will be very similar to the rear door in procedure. To swap the glass I had to basicly pull out the regulator as well, which involved rolling hte window down a little so the bolts and plastic retainers where accessable through the two barely-big-enough holes in the sheet metal.
