Posts: 6,106 |
Originally posted by racerbox77: the factory air box is shaped like a cone around the filter. it has a small hole at the end which is connected to the little elbow which runs into the fender
Originally posted by Y2KSVT:
I know exactly what you're talking about. I've had my SVT since it was brand spankin' new. First off, you're going to want to remove that little elbow in your intake, it's a pretty big restriction of airflow! What "CAI" are you going to be running? Is it the GMK unit?
Mark
Originally posted by racerbox77: what elbow?
Are you serious?
Mark
2000 Black CSVT
Posts: 7,100 |
Originally posted by racerbox77: Originally posted by Y2KSVT: You obviously haven't paid any attention when drag racing, or you have a rigged track that gives people false hope! An 89mph trap with a 2.55 60' time would be around a 16.0-16.2! For you to run a 15.0 with the 60' time you had, you'd need to trap closer to ~96mph.
------------------------"WRONG"
No... that was right.. a trap of 95-96 would be REQUIRED to pull off a 15.0x with a 2.5x 60'.. plain and simple.
As for launching, good luck with your differential. With 3500rpm launches and reving to 5000rpms, you're sure to be either clutchless of diffless.
------------------------"MAYBE"
not a maybe.. your differential is SCREAMING at you to take it easy.
Ray
'99 CSVT - Silver #222/276
Posts: 6,106 |
Originally posted by racerbox77: Originally posted by Y2KSVT: 1: You obviously haven't paid any attention when drag racing, or you have a rigged track that gives people false hope! An 89mph trap with a 2.55 60' time would be around a 16.0-16.2! For you to run a 15.0 with the 60' time you had, you'd need to trap closer to ~96mph.
2: As for launching, good luck with your differential. With 3500rpm launches and reving to 5000rpms, you're sure to be either clutchless of diffless.
For an optimum launch, I rev to about 2800rpms. At the line I'll let the clutch pedal out until it's almost about to grab. Once ready(when I get the green), I start to slip the clutch and rev the motor to keep the rpms at about 2800-3100rpms. Once you've got a little momentum and you've completely let out on the clutch pedal, you'll be right at the point of your secondaries opening and your powerband begins. After that you're on your own.
Mark
3: ------------------"YOU RUN ? W/ 3.0L???"
1: Bold statement you've made there. First off, YES you are WRONG! You will NOT run a 15.0 with a 2.55 60' time. I now see that you've changed your mind on what you ran, and conveniently changed your 60' time to a 2.25. When you want to come back with your timeslip, we'll talk.
2: Maybe? You're not talking to a newbie that's never broken a part on his car! You're talking to someone that frequents the dragstrip probably 10-12 times a year, blown a motor, 2 trannies, etc.. I know what it takes to break parts!
3: I ran a 14.4 with my 3.0L. Can't wait to hear what you've got to say about that!
Again, when you want to come back with FACTS, and not made up BULLSH!T, we'll talk. Until then, STFU!
Mark
2000 Black CSVT
Posts: 184 |
Originally posted by Y2KSVT: Originally posted by racerbox77: the factory air box is shaped like a cone around the filter. it has a small hole at the end which is connected to the little elbow which runs into the fender
Mark
Are you serious?
Mark
i thought it was self explanitory that that piece was gone. what purpose would it serve if the filter housing wasnt conected to it anymore??
Posts: 184 |
AGAIN 2.25 sorry bout that didnt realize my misprint.  2.5 would be a slow pass. agin not made up. dont care if you believe or not. well i guess i do care, because if it is soo hard to believe that im doing that, and i am, then i deserve props not bashing. i know breaking stuff sucks. ive turned a wrench or 2. also what was your 60 ? mph?
Posts: 6,106 |
racerbox77 - I've come to the conclusion that you are not going to listen to anything I've said. I've tried helping you, but you are going about it like an ignorant newb. You've been on the boards for a mere 15 days and you think you know it all? I'm now backing away, and will let you believe your own fictional stories.
Mark
2000 Black CSVT
Posts: 184 |
ignorant- no lack of proof reading-yes does it matter how long ive owned my car, or how long its been since i started posting on this board? yes -for contour specific things, but general car talk -no. So far my fastest car has been a 89 mustang 5.0 which ran 11.50s on slicks. then i had a 85 iroc-z which ran 11.90s, a 69 chevelle 12.20s, 96 saleen mustang 13.60s, 97 probe gts 15.20s, etc...my dad's car won the "Fastest Street Car Shootout" in 01' and we came in 2nd in 02' (8.19 @ 166 mph street legal)his web site is www.BOXPERFORMANCE.COM (check out the "TOOL BOX" section for horsepower calculators and top speed,etc. just trying to tell you i may know a little more than you think. -check out the site...  anyway ill post slips hopefully tomorrow.
Posts: 5,810 |
Nice stuff on that website. You say that is your dad? Cool. Is he ever going to do anything with front drive vehicles?
See My Mods
Posts: 1,516 |
Originally posted by racerbox77: TourdeForce sent me an email as to why exactly those plugs arent good. It made sense and I wont buy them again, but I just put them in about 500 miles ago. If I start to notice a problem Ill change them out for some Autolites, as he suggested.
Im about 45 minutes from Norwalk Raceway. You?
Originally posted by racerbox77: Hey Mmarfan,
what was done to your SE? thats almost exactly what my car runs.(or ran, last time)
I'm more toward the Cincy area, so I'm much further away.
The SE had:
APEXi SAFC
SVT upper and lower honed and port matched
2.5 inch exhaust split to 2.25
short ram "cold" air intake
65mm throttle body (which is for sale if anyone wants it, it includes a TPS with it)
15 inch stock alloy SE style wheels.
Eibach springs/ Koni struts
Mazda 6S, V6, Speed Yellow
5 Speed, Sport package
Bose audio
Painted 'stash and HIDs!
w/Injen 1/4 14.750 @ 94.94
Former car:
99 Contour SE Sport Black MTX V6
SVT plastic...
1/4 - 15.012 @ 90.58
Posts: 184 |
Originally posted by warmonger: Nice stuff on that website. You say that is your dad? Cool. Is he ever going to do anything with front drive vehicles?
yes, he does all types of cars, and bikes. he did a head for an srt neon just last week. he will do tour heads as well. well do mine, but im going to wait till the motor breaks before i pull them off.(the motor WILL break)
