Page 5 of 9 1 2 3 4 5 6 7 8 9
#1302789 06/17/05 05:34 PM
Originally posted by elraido:
Don't stock 95 SE's hit 15.9 or seomthing like that?
NOT with a 2.5-2.6 60' time. That's the point.
The 1/4 mile time he is stated would be excellent for any SVT.
It's just not going to happen with such a horrible launch and 1-2 shift.
A 2.55 verses a 2.25 60' time will be nearly .5 seconds slower at the end of the 1/4 mile. So that's like stating a near stock SVT would run low 14's with a 2.1-2.2 60' time. NOT GOING TO HAPPEN!
#1302790 06/17/05 05:58 PM
mph on the 15.08 run was 89 mph. my best mph was 90.7. so nobodys doubting my mph its the et. Im not lying -why would i??? the mph is on par with others the et is lower. so the horsepower is average.(because mph = horsepower) guys, being close to sea level matters. also i dont know how experienced others are but ive been drag racing many many times in the past 12 years. how are you guys launching on street tires? ive read 3500rpm ... i rev it to about 5000 and slip the clutch./ not enough to burn it up./ the tires spin barely as the car propells forward and when the tires hook 100% the tach doesnt go down and the car doesnt bog. at that point the tach is around 5500 and then i slam 2nd hard at 6800rpm
-forgot about my Fidanza flywheel.
99 SVT "nice" 14.67 @ 92.6 mph (street trim) FOR SALE contact KEVIN.BOX@CINGULAR.COM http://www.cardomain.com/ride/1592122
#1302791 06/17/05 06:03 PM
Originally posted by DemonSVT:
Stock is 15.3ish with perfect everything.
Normal is 15.5ish
Traps around 90mph.
so if thats stock why wouldnt you believe with my mods i could chop 2.5 tenths???
#1302792 06/17/05 06:16 PM
Y
Y
You obviously haven't paid any attention when drag racing, or you have a rigged track that gives people false hope! An 89mph trap with a 2.55 60' time would be around a 16.0-16.2! For you to run a 15.0 with the 60' time you had, you'd need to trap closer to ~96mph.
As for launching, good luck with your differential. With 3500rpm launches and reving to 5000rpms, you're sure to be either clutchless of diffless.
For an optimum launch, I rev to about 2800rpms. At the line I'll let the clutch pedal out until it's almost about to grab. Once ready(when I get the green), I start to slip the clutch and rev the motor to keep the rpms at about 2800-3100rpms. Once you've got a little momentum and you've completely let out on the clutch pedal, you'll be right at the point of your secondaries opening and your powerband begins. After that you're on your own.
Mark
#1302793 06/17/05 06:16 PM
Originally posted by Y2KSVT:
Originally posted by tour96se:
so basically you have a aftermarket y pipe to make the car quicker...
That's what I've gathered from his mod list. The part I don't get is where he says that cutting the factor airbox is better than a heatshield and an open filter. The MAF screen isn't going to net an HP, 18" wheels(more than likely heavier than the stock 16"s and tires) are going to slow him down. And with a 2.55 60' time, he'd be hard pressed to break 16's!
By the way, what was your mph?
Mark
i also have a fidanza flywheel.
the factory air box is shaped like a cone around the filter. it has a small hole at the end which is connected to the little elbow which runs into the fender(99 svt). what i did is put in a k+n cone style filter and took out the screen(had to do some fabbing to make the factory adapter fit snug against the maf)then i cut in a circle about 5 inches of the black plastic housing that surounds the filter off this gives it more air and sheilds it from heat.
total cost = $45 filter/labor=free /cut finger=free
this set-up will be for sale if anyone wants it as soon as i recieve my cc cold air intake.
#1302794 06/17/05 06:19 PM
I live AT sealevel, and every track I've ever been to is sealevel (I haven't had the ability to experience things such as Denver (from a racing perspective).
Sea level will NOT cut that time off FOR you. EVEN at sea level, you'd have to trap at ~95mph to get that time with a 2.5x 60'.
EDIT: I see Y2K beat me to it. I should've read it more thoroughly.
Ray
#1302795 06/17/05 06:22 PM
Y
Y
I know exactly what you're talking about. I've had my SVT since it was brand spankin' new. First off, you're going to want to remove that little elbow in your intake, it's a pretty big restriction of airflow! What "CAI" are you going to be running? Is it the GMK unit?
Mark
#1302796 06/17/05 06:23 PM
------------------------"WRONG"
------------------------"MAYBE"
Mark
------------------"YOU RUN ? W/ 3.0L???"
#1302797 06/17/05 06:25 PM
Mark
what elbow? the thing that used to go into the fender? its been awhile since that mod, i dont remember an elbow.
custom cougars cold air is the one.
#1302798 06/17/05 06:30 PM
Ok guys went to the track last night fully expecting 14s with my newest mod(y-pipe). BUT it didnt happen 15.08 was my best and that was with my best 60 ft so far 2.55. (with my nitto neo gens Ray) every other run netted me the same times as before the y (15.12,15.21,15.14 at 89.7-90.5)
------------ WHOOPS! I meant 2.25, sorry..
Moderated by  mbb41_dup1
