#1302722 06/11/05 09:21 PM
alexey Offline OP
My a/c is cooked on my 98 v6 mtx and i wanna get a smaller belt to bypass the a/c altogether... how can i go about doing that?
Lexus ES300
N
N
I don't think that ou will be able to find an OEM replacement belt for a V6 w/out A/C. All V6 comes standard with A/C.
I don't think that you can either find a belt taht will fit on your engine w/out the A/C compressor, because of the drive belt pattern.
You can do is try finding an idler pulley and bracket that you will install in place of your A/C compressor.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
alexey Offline OP
hmmm... i dont get it... im sure if you just get the right size it can be done... its just a belt
Lexus ES300
A belt for non a/c exists, and will work. Check out your diagrahm, located on the passenger side of the engine bay, that illustrates belth routing for a/c and non-a/c. no interference. I am sure Autozone, or your local parts store would carry a belt for a car w/o a/c.
Ray
alexey Offline OP
awesome!! another thing.. i've never done the belt myself... how hard would it be to do???
Lexus ES300
3/8 breaker bar (no getting around this part!!!)
You can either go from the top, passenger side, about even with the motor mount (but slightly below it)
OR
from the passenger wheel well, remove the splash shield, and fender liner, then you can easily access the tensioner from there. (MUCH more "turning" room than up top, though it takes longer to get to b/c of the shield/liner)
turn it clockwise (if standing on passenger side, facing car.) to remove tension from belt. While holding, remove belt from on pulley (recommend A/C pulley as it is the furthest, and gives the most slack.. bottom right from pass.side. facing car)
release breaker bar, snake old belt out from behind tensioner pulley, remove.
replace in same routing (with treads facing the same direction, not "flipped" over.. follow diagram on car...)
remove tension, add belt to A/C pulley once more.. release tensioner.. done.
15 minutes, MAYBE!!!!
Ray
As I've been trying to tell people you can lookup all the part numbers at http://www.motorcraft.com
1998 Ford Contour without A/C
Part No.: JK6-632-B
Manufacturer: MOTORCRAFT
Part Type: BELT, SERPENTINE
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
