Posts: 219 |
The stupid TPS screws won't come out without getting striped!  Guess I'll have to use a small pair of vise grips and grab them around the outside of them. I didn't spend 25 bucks on emory cloth, files, screws and countersink bits for nothing!!!
Posts: 1,356 |
Mine were a pain to get out too. I ended up using the best fitting philips I had, putting it in a 1/4" socket and using a ratcheting wrench to get it out. It still wasn't easy, but it worked and the screws didn't get chewed up...
Good luck with it!
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 10,015 |
Put it in a vice and then put the screwdriver on each screw and hit each screw with a hammer to loosen the rust/oxidation.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 6,700 |
PB Blaster is your friend, guys. Soak the two screws with a couple squirts for a few minutes and screw them off. Just clean it up when you are done with some TB cleaner.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 9,602 |
Sounds like you used too small of a screw driver for starters.
They are tough to get out but with a properly sized screw driver and downward force you can break the loctite used on them.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 219 |
It's cool. My #2 phillips would fit but the screws are so darn soft. My #3 phillips was too big. I used a hacksaw and made them flatheads and they finally came out. I got-r-done and yes I can "feel" the difference in response. Not as much "lag" I guess would be the best term. Chalk up one more Mod!!!
Posts: 5,810 |
See My Mods
Posts: 1,356 |
Did you notice a difference with th optimized Y-pipe??
1999 Mystique LS V6
Posts: 219 |
Yes I did not much but you can tell slightly more pick up and overall sound just a touch louder. Got mine done for $50 at local muffler shop.
Now just waiting to join the ranks of three others that posted on here wit da tree liters
Posts: 3,732 |
impact driver is your friend  it will get the screws right out
Russell
Oval Port 3L Nearly Done
