#1301740 06/10/05 06:51 AM
I understand that the e-brake cable listed on the drum 2 disc conv. is a cougar part. I found out that there is another cable that is listed as a TSB cable kit with both sides in the kit and has return springs. Anyone use this kit? part # is F6RZ-2A635-AA.
'00 T-Red TourSE 2.5L ATX Foglight Mod,Optimized Y-Pipe & TB, FSVT F/P,RU-3530 http://www.cardomain.com/memberpage/688552
#1301741 06/10/05 12:09 PM
yes, but not for a swap, the kit comes with two cables and the return springs which you only need for the 95 I beleive
#1301742 06/10/05 05:21 PM
E
E
my ebrake no worky, this is the kit number that should make it work right? How much is the thing anywho.
95 SE MTX svt exhaust intake deer killer
#1301743 06/11/05 05:42 AM
sorry not sure on the number but if you ask for the kit it shouldn't be a problem, last I knew Ford only sold the kit anyway, thats how we ended up with two sets, but semi luckly we ended up with my 99 and it needed cables just like the other 99 so we had the set already
#1301744 06/12/05 04:18 PM
Steve at Tousley Ford said the brake cable in the How-To is 27.10 Ea. Bill quoted 30.80.(Cable sold separatly)
However The TSB cables has both sides and Bill said that would run 43.71(Cables sold together)
Steve quoted that same one at 38.47.
I just wondered if people doing the conversion were using F8RZ2A635FA(Cougar) or F6RZ2A635AA(Contour)?
#1301745 06/15/05 02:10 AM
E
E
who is the one in white bear lake MN? I can just drive up there and get it sometime.
Moderated by  Andy W._dup1
