#1300556 06/09/05 03:19 AM
If the rear o2 sensors just measure the catalyst of the gases after the cats, will they make the car run odd if I have gutted the pre cats? I am getting a code that is saying bank 2 lean condition. So I was wondering if that is the problem or if one of my pre cat sensors are bad. I also am experiencing a slight studder in fourth gear with the RPM's around 1300 and doing about 35 miles per hour. Are these problems related or is there more things that I should look at? Thanks
Oh and I was also wanting to know if there is any way to shut off the rear sensors, without buying a chip and putting the MIL eliminators in.
98 SVT 18" Enkei RS6's, NITTO 555 Extremes Intrax lowering springs K&N filter Sho-Shop Y pipe (without cats) Stock "gutted" manifolds Carbon Fiber Cowl hood Carbon fiber sail panels
#1300557 06/09/05 03:42 AM
to turn off the o2s you will need MILs OR a chip. one or the other. if you dont feel like springing for the MILs (the cheaper option) you can always make them yourself. there is a how to for that around here somewhere.
secondly, gutting the cats will make you throw another code (or your first one if you dont have a CEL already).
either way, you need to do something!
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
#1300558 06/09/05 04:22 AM
So if I get something to shut off the rear sensors then technically I shouldn't get a code for gutting the cats? Correct?
#1300559 06/09/05 04:43 AM
correct.
also, your lean condition code has nothing to do with the cats being gutted..
'only upstream sensors monitor fuel ratios
downstreams ONLY monitor cat efficiency.
Ray
#1300560 06/09/05 02:47 PM
Well now I have an idea about what is happening. Thank you guys for the help.
