You and I are in the same boat at the same time... and with the same vehicle.
I have started to do what I can on my own, which is limited.
So far I have replaced the rear sway bar bushings, which is rather easy, and the front sway bar end links (a bit harder, but not bad). I cannot do the front sway bar bushings myself and I need to do more research before getting the rear end links replaced (which are in horrible condition).
If you do the struts yourself, you will need a spring compressor. Whether you are replacing the springs or not, you will still need to remove them from the strut/shock absorbers. Both spring and strut are removed from the vehicle as one unit. You then need to remove the spring from the strut/shock absorber and put it on the new one (or replace with new); then the whole assembly goes back into the vehicle as one unit. At least according to what I have read.
Also my dust boots on my struts are wasted. I replaced my front end links today and noticed the boot on the passenger side was not even covering the lower 4" of the strut inside the spring.
My car bounces and rattles like crazy, especially on my dirt driveway. I have a friend who lives about 4 miles back a dirt road... I hate driving there.
The only thing holding me back is $
