Jeff,
I applud the final concensus: finding the reason for the blown fuse.
I have seen shorted resistors (albeit a wirewound one, but still) We were required to troubleshoot a circuit with one inserted as a controlled fault when going through the Naval Electronics Technicians Training School (NETTS)
While I don't have 35 years of experience, I do have 8.
I focus mainly on UHF, VHF, LF, VLF, and SATCOM transmissions (Radar propogation, and control, HF communications transceivers , etc)
I also work in Miniature and Microminiature soldering (up to 400x) through NAVSEACOM, as well as Fiberoptic termination and repair.
I will admit that I see no reason to cause the blown fuse, but think about this now: you've been doing this for years... how many times have you had a fault that you found and the words that went through your head were LITERALLY, "what in the hell"???", when you thought about WHY it happened.
It doesn't ALWAYS make sense, though we wish it would(certainly makes troubleshooting easier).
End result: this guy needs to find the problem. I won't argue that much. Can a blown resistor cause the fuse to keep blowing? it CAN, I have had it happen. though I couldn't explain it, and I won't begin to try. Can a resistor short? sure, but you wouldn't see it on any NORMAL earth day!
Good explanation of the circuit, btw, Jeff
Ray
