Posts: 451 |
i have heard if you put a 170degree thermostat on it will trick the computer so it richens the fuel is that true and is it safe
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Posts: 6,106 |
i have heard that if you use correct punctuation and grammar and not run-on sentences people will understand what you are saying do you know what i mean
But to try and answer your question, adding a lower temperature thermostat will not make your car run rich. It will make your car run cooler, as the fans will kick on earlier.
Mark
2000 Black CSVT
Posts: 6,700 |
Originally posted by lizard: i have heard if you put a 170degree thermostat on it will trick the computer so it richens the fuel is that true and is it safe
Coolant, thermostat, radiator... has nothing to do with whether te car runs lean or rich. And (obvious), the cooler a car runs, the better. 170 degree thermo will jus tallow the main cooling fans to kick on sooner, no damage done to the car.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 6,760 |
actually it does. I don't remember the specifics but it has something to do with the EEC and closed / open loop IIRC....I'm sure Greg will chime in and explain it in detail. Mustang guys try to do this IIRC.... Originally posted by LilStrypedSVT: Originally posted by lizard: i have heard if you put a 170degree thermostat on it will trick the computer so it richens the fuel is that true and is it safe
Ryan
Trollin!
Posts: 10,015 |
You can actually use a 160�°F stat, which does let the ECU run more fuel AND more advance on the spark.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 411 |
The colder T-Stat allows the cooling process to begin sooner - i.e. coolant flows sooner. The fans kick on whenever the PCM tells them to- which is preset. Altering the "on temp" requires a chip or an external fan switch to change the point at which the fans come on.
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Born on March 16, 1998
"If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Posts: 451 |
is it harmful to use a 160 stat
2000 contour V6 ATX
Posts: 10,015 |
No, but what is your reason for wanting it? If you think you're gonna get a big boost in power - think again.
AUSSIE ENDLINKS $70
Posts: 451 |
no one mod will give you big boost in power besides supercharger or turbo. im just trying to get most out of engine before i get a chip
2000 contour V6 ATX
Posts: 10,015 |
Trust me on this, you're wasting your time.
Unless you are making a LOT of hp and are getting more heat into the engine, like a turbo, supercharger, nitrous - you don't need it and won't see gains from it.
AUSSIE ENDLINKS $70
