Posts: 258 |
If the battery light is on, I would check the alternator amp/fuse. I had that go a while back, its a 135 amp fuse and it set off hte battery light and i was losing power rather quickly and the alternation wasnt getting enough power to recharge the battery. Good luck w/ everything chris!
96 Contour
Clarion VRX935VD
My Car
Posts: 3,788 |
Glad you got her running again. Hopefully it will be fine until the swap.
Posts: 4,292 |
sh!t...the one on the altenator??!?!?!?!....i'm not changing that thing again...
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 9,196 |
I knew you'd keep the car, good job
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 258 |
Originally posted by tour96se: sh!t...the one on the altenator??!?!?!?!....i'm not changing that thing again...
Its a pain in the a$$ i know!
96 Contour
Clarion VRX935VD
My Car
Posts: 2,838 |
Ya-hoo ! It's running again ... albeit with a small issue . At least you found the wiring problem rather quickly .
~~~~~~~ Phil
Black & Tan 2000 SVT Contour #2137 of 2150
35,000 miles & counting !
Posts: 4,292 |
figured out that the csps harnes was split fixed that car ran fine...then the battery light came on...and the altenator sh!t the bed on my way to work this morning...
Posts: 6,106 |
Didn't you replace the alternator just 7 months ago? I presume it was a new/rebuilt alternator? You most likely have a 1yr. warranty on it. You might be able to get it replaced. And I know, the labor is the b!tch of it all!
Mark
2000 Black CSVT
Posts: 4,292 |
Originally posted by Y2KSVT: Didn't you replace the alternator just 7 months ago? I presume it was a new/rebuilt alternator? You most likely have a 1yr. warranty on it. You might be able to get it replaced. And I know, the labor is the b!tch of it all!
Mark
.. damn son..and i thought i was observant thats exactaly when i replaced it....... yeah but the way i weighed it out...replace the altenator or replace the whole front subframe...it took me 9 hours to do the altenator..granted it wouldnt take me that long again..so i'm changing the front
Posts: 6,106 |
Daaaaaamn!!! 9 hours for an alternator!! YIKES!! I haven't had to do my own yet, but I know that it took me about 3 hours of fighting with Jim's car to get the old one out and the new one in. Damn his turbo piping wrap has some sharp corners! Mark
2000 Black CSVT
