Posts: 9,196 |
It really sounds like a fuel pump or possibly a clogged cat, if you've still got one. I think cooler heads will prevail in this one and if you do get another car, what are you lookin' at?
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 4,292 |
no cats..........i changed the fuel filter,and cleaned the sock on the pump...it'll run fine for about .5 mile..and it will idle fine but as soon as i put any type of pressure on it it starts backfiring....now isnt backfiring a sign of too much gas?
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 10,015 |
Sounds like a stuck injector.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 2,426 |
Originally posted by SVT PETE: Try and fix it Chris!
Don't even think of selling her! She's just got a cold or a cough. You've got one the few truly unique pre 98's around. If the same thing happened to me, you'd be saying "fix it" to me too. It's just the Contour God screwing with you cause your car looks soooo good!
Posts: 4,292 |
Originally posted by wa2tuff: Originally posted by SVT PETE: Try and fix it Chris!
. ..........wrong...if it was you i'd telling you to part that b!tch...that way i could pick up some stuff!!! ....how would i fix a stuck injector?...i have the 19lb ones...
Posts: 6,700 |
Originally posted by tour96se: Originally posted by wa2tuff: Originally posted by SVT PETE: Try and fix it Chris!
Replace it
You can techically follow the UIM/LIM rebuild aide (from Ray) to get to the injectors. There was a set of 6 injectors in the classifieds a few weeks ago.. might still be there.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 4,292 |
okay....dead post..i know i can replace it..but $$ that sucks...i met a guy at carlisle that had a rolled csvt..still runs fine, i'm buying it for 600 ...looks like i'll be doing a complete subframe swap..in the next week or so
Posts: 6,700 |
Originally posted by tour96se: okay....dead post..i know i can replace it..but $$ that sucks...i met a guy at carlisle that had a rolled csvt..still runs fine, i'm buying it for 600 ...looks like i'll be doing a complete subframe swap..in the next week or so
WOW! Awesome man! You just going to do a powertrain swap?? Congrats on the find!
Posts: 285 |
Before you go changing injectors, check your fuel pressure. You may have a bad regulator which will make you run rich, causing stalling and black smoke, BUT with the back fire from the exhaust it could be an ignition problem. You may want to check your ignition coil as a possible suspect. Usually when they go bad it will start and run until it heats up and shorts(could be seconds, minutes or hours). A bad ECT, TPS or MAF could also cause the same symptoms and it may not throw a CEL because the car wouldn't be running long enough to. Plugging it in to a diagnostic computer (NOT a code reader) should point out a dead or dying sensor in the short time the car will run.
Parting out 95-97 Contours/Mystiques. Contact me directly at ALFIGOLS@yahoo.com if you're looking for a particular part.
Posts: 6,700 |
Originally posted by Figols: Before you go changing injectors, check your fuel pressure. You may have a bad regulator which will make you run rich, causing stalling and black smoke, BUT with the back fire from the exhaust it could be an ignition problem. You may want to check your ignition coil as a possible suspect. Usually when they go bad it will start and run until it heats up and shorts(could be seconds, minutes or hours). A bad ECT, TPS or MAF could also cause the same symptoms and it may not throw a CEL because the car wouldn't be running long enough to. Plugging it in to a diagnostic computer (NOT a code reader) should point out a dead or dying sensor in the short time the car will run.
Looks like he didn't get the memo!
