I want to reset the onboard computer to default settings. I believe this can be done by disconneting battery for 30 minutes. Which terminal should I disconnect (positive +, or negative -, or both) ? Thanks.
Either disconnect the battery or pull fuses #4 and #11 for a couple of minutes. Then hook up the battery or replace the fuses. This takes it back to factory settings. Works on my tour.
Col. Bill Evans CAF (ret)
98 Contour GL Zetec ATX (totally stock)
Color-Willow Mist
104,XXX Miles
