Originally posted by Stazi: The larger the tire diameter the "flatter" it acts as it contacts the road, so he is right in saying the the contact patch is larger on a bigger diameter tire - if you assume that there is the same amount of tire deflection on both tires.
Stazi thank you. thats what i was trying to say just couldnt find the words. Demon is correct and as i posted before the difference in our aplication would probably have zero effect on traction, and runnning a 225 as apossed to running 205 would make a much bigger diff.(i can attest to that) I was just trying to make a point.
