Posts: 4,270 |
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 712 |
so upon further inspection.. i do have them in wrong  could the clips be causing all of my problems??? wow i hope so, i will put them on right tonight.
1998.5 Diamond White Pearl SVT (#4725)
custom exhaust/intake k&N/mod'ed y-pipe
slotted rotors/greenstuff pads/SS lines
cougar trans/FSVT shift tower/Torsen
16lb. flywheel
18" Velox VX-8's with some rubba bands
Posts: 4,693 |
Guys, I'm still new with a digital camera. I tried to use photobucket to post pictures and couldn't make it work. So here is an attempt with car domain. There are two pictures of the car and then 5 pictures of the brakes including the tool I use on the clips.
[url=http://www.cardomain.com/my/]http://www.cardomain.com/my/
[/url]
Try this one:
http://www.cardomain.com/ride/1153968
Jim Johnson
98 SVT
03 Escape Limited
Posts: 712 |
photobucket is pretty easy, and car domain is also popular, but your link is bad... i wanna see the tool, those things are a total PITA!!
16lb. flywheel
Posts: 4,693 |
I guess I still haven't figured it out. I can't find any instructions to tell me how to link it. You should be able to find it under my car domain name "jjhaven".
See if this works (same as edited above):
Jim Johnson
98 SVT
03 Escape Limited
Posts: 3,065 |
Posts: 2,007 |
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 712 |
Your brakes look nice!! but i put my clips on right and i still have the wicked brake problem, i think my next route is to get the stock rotors tunred and some stock pads and see if it still does it.. any suggestions because i am 100% clueless
16lb. flywheel
Posts: 712 |
Originally posted by Stylin55_oh: So, I've got a brake problem that no one seems to be able to diagnose, and if i cant find any more suggestions im going to take it to a shop. (I'm 21, own 3 cars and have never taken a car to a shop for anything besides tire balancing) Here's the outline. One day after a hard stop (the next day) i noticed my car would jerk to the left when i hit the brakes, didnt matter how hard i hit the brakes. It isn't like a constant pull you off the road, but it is a considerably big first jerk when the brakes first start to grab. Also the steering wheel turns about 1/8 of a turn to the right (opposite way the car moves). I tried new SS lines, thinking i might have a leak. fixed nothing. I cleaned and relubed calipers and actually replaced one. fixed nothing. I switched to full synthetic brake fluid. fixed nothing. I've checked all steering and suspension components and found no culprits. Steering by the way is perfect, no slop, tight as ever... but jerks when the brakes are applied.
anyone got any ideas?!?
sometimes people dont follow up when they get something fixed, but im going to incase this happens to anyone else. The culprit... [drumroll]... bad passenger side LCA bushings. Replaced the right side LCA everything is grrrreat! LOL .. well except i dont have quite the pedal feel i had before all of my brake drama.. and i have added SSlines in the process... odd but oh well it stops straight and true
16lb. flywheel
Posts: 1,593 |
Originally posted by Big Jim: Guys, I'm still new with a digital camera. I tried to use photobucket to post pictures and couldn't make it work. So here is an attempt with car domain. There are two pictures of the car and then 5 pictures of the brakes including the tool I use on the clips.
[url=http://www.cardomain.com/my/]http://www.cardomain.com/my/ [/url]
Try this one:
Question. I was searching the brake forum, because I noticed something on my car this past weekend. I was painting the calipers, and noticed that this retaining clip is missing on my passengers side front caliper. I had some work done there a month or so ago (new wheel bearing) and I don't know why they might have taken this clip off, but it is missing. It may have been missing for much longer, I don't know.
How big of a problem is this? Where do a go for a replacement? What does this clip "retain" the pads?
At the same time this work was done, he said that rotor was stuck/ rusted on there so bad he had to cut it off and replace it. I want to replace the other three (they are rusting pretty badly I noticed while I was painting). Any tricks to getting them off? I don't have any way of cutting them off. WD 40, PB Blaster, etc. would that work?
Thanks in advance for any help anyone may be able to offer.
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
