Posts: 718 |
Nope it is NGK TR6. They exist...i just bought some 2 weeks ago.
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 3,637 |
Originally posted by 99cougar: Nope it is NGK TR6. They exist...i just bought some 2 weeks ago.
I checked summit and they had some.
Just wondering if TR6's are to cold for the Canadian winters or if i would be better off with NGK TR55's
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 9,602 |
TR6 (1 heat range colder then stock) will drop MPG and worsen drivability. I would recommend putting them in when you are going to run nitrous. If you will run it a lot over the summer then running 1 step colder for the summer is passable. You still will have the above issues.
I would not recommend running them in moderate temperature weather or lower as these issues worsen noticeably.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,637 |
Originally posted by DemonSVT: TR6 (1 heat range colder then stock) will drop MPG and worsen drivability. I would recommend putting them in when you are going to run nitrous. If you will run it a lot over the summer then running 1 step colder for the summer is passable. You still will have the above issues. I would not recommend running them in moderate temperature weather or lower as these issues worsen noticeably.
TR6 are 2 steps colder than Autolight APP764's
TR55 are 1 step colder.
So TR55's it is (need driveability and the ability to run the giggle juice)
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 718 |
Well i drive with them everyday, and i get about 26-28mpg. I notice no drivability issues either.
Then again i am in Hardeeville, SC where the high temp. has not been below 90 in well over a month!
1999 Cougar V6 MTX
Posts: 3,637 |
im thinking ill just get a set of TR6's for the summer, as soon as they start driving bad ill switch to TR55's in the winter (or just back to autolites cause i doubt i'll be spraying in winter)
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 718 |
Originally posted by Tourige: im thinking ill just get a set of TR6's for the summer, as soon as they start driving bad ill switch to TR55's in the winter (or just back to autolites cause i doubt i'll be spraying in winter)
That would probably be better. I am not saying mine don't drive bad in the winter, i just don't have experience with TR6's in the winter yet. I moved to TR6's when i moved to the 100/125 shot which was just 6-7 weeks ago. All during the winter i ran TR55's without a problem.
1999 Cougar V6 MTX
Posts: 3,637 |
Originally posted by 99cougar: Originally posted by Tourige: im thinking ill just get a set of TR6's for the summer, as soon as they start driving bad ill switch to TR55's in the winter (or just back to autolites cause i doubt i'll be spraying in winter)
in south Carolina.. I live in Calgary Canada. It gets to about -25 sometimes in the winter (-13 Farenheit)
Ill try that, the plugs are pretty cheap anys ways (24 bucks for 6)
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 718 |
Holy crap! $24 ![](/ubbthreads/images/graemlins/eek.gif) I pay $1.77 apiece for TR6's or TR55's at the local Advance Auto. I could get two sets of plugs for less than $24!
1999 Cougar V6 MTX
Posts: 3,637 |
Originally posted by 99cougar: Holy crap! $24 ![](/ubbthreads/images/graemlins/eek.gif)
autolite APP764's are 64 bucks for 6 here..
230.2 WHP @ 6500
237.0 WTR @ 2250
