#1292859 06/01/05 03:28 AM
Pole120 Offline OP
wondering if anyone has any experience with interior paints and dies for car interiors, i'm looking to make some changes, and i'm looking for the best tool for the job.
thanks
pole
#1292860 06/01/05 06:17 AM
what surfaces and materials are you looking at doing?
99 csvt 68 cuda fastback 340 00 gp gtp (wife) 01 gs500
#1292861 06/01/05 12:37 PM
Pole120 Offline OP
plastic, possibly vinyl.
#1292862 06/01/05 01:19 PM
The are good grades of interior paint at autobody supply shops...you have to use flex agent on any kind of plastic. This is the best paint to use, but it is still prone to scratching & chipping easily.
The panels you are painting must be thoroughly cleaned (I can't stress this enough)... any armor-all residue can really screw up a decent paint job
1999 Sportage 4x4...don't go there, it was free ....______o_o .../_l l__\____\ ..|--l l__----[]\|/[] .....................oo =( )_)----( )_)--)_)
#1292863 06/02/05 02:45 AM
the plastic stuff is pretty easy. like svzetec said though be sure it is clean. and i have found that it helps to give the pieces a slight brush down with some fine grit paper before also. as far as the paint goes, i have had no problems whatsoever using the duplicolor paint and clear. that is if you are looking to use rattle cans and not a gun setup. there are some pics on here of mine when it was partially done if you want to look.
#1292864 06/02/05 05:03 AM
depending on the color you want you should try krylon fusion paint for plastic...if you get a glossy color you won't need a clear...i just painted my trim with nickel shimmer its a great silver/gray color....i also sanded mine down a bit and used a coat of primer,and they turned out great....that fusion paint really hardens up and bonds to the plastic after a few days
new,new ride! '99 svt black/mnb '95 mustang gt sold! '98 svt #800 sold!
#1292865 06/02/05 02:49 PM
i did my center console,a & b pillar,the door switch bezels,and the instrument bezel with dupli color color changing paint and that was over a year ago and they are still great, i have used krylon fusion for exterior parts and some interior on a friends and its awsome.....
#1292866 06/06/05 03:23 AM
Pole120 Offline OP
i'm going to experiment with satin black krylon fusions tomorrow or tuesday
i'll let you know how it works out, i'm going t otry it on an extra pannel i have before i spray my entire interior
i am worried aobut odor......
#1292867 06/08/05 03:46 AM
I used blue Krylon Fusion on both of my front door panels and after a good 4 hours its still tacky on the vinyl
It's probably just the humidity
Maybe some clearcoat might make it harder ...
CoolBlackSE99: proud owner of a 99 Contour SE Sport V6 MTX My cardomain page
#1292868 06/08/05 04:11 AM
Pole120 Offline OP
why would you put krylon fusions(for plastic) on vinyl thats what vinyl dye is for
