#1292773 06/01/05 02:14 AM
R_G Offline OP
Well, as my luck had it - on our both cars the A/Cs went south within the last 3 days, first on Duratec and then on Zetec (think conspiracy?)
Actually what happened was - we just turned our respective A/Cs on for the 1st time this year - and both of them kept blowing hot air though last time we checked (a year ago LOL) they worked fine.
The question is - apart from the obvious causes like leaks - are there any common A/C malfunctioning problems associated with Contiques?
Also, what the average damage I should ready myself for?
JB1 Offline
beyond leaks it could be a mechanical problem. not using the ac for a for year can have alot to do with it. expect $700+ to have someone do it. if possible replace the parts your self and have pepboys or someone fill er up. that will save quite a bit. this assumes you have bad parts. first check the refrigerant.
00 black/tan svt, #2052 of 2150, born 2/1/00 formerly known as my csvt "Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
I would just check the refrigerent level. Get one of those kits at an autoparts store, and you can add more refrigerant if you are low. That should fix the problem temporarly, however, that also means you probably have a leak somewhere, I don't know how much it would cost to find and fix that, but I would estimate a mild ass rapage if you are doing it on two cars
Cameron 98 Black CSVT #2958
Just recharge it yourself. Expect to pay $20-$25 for the first car, but only around $10 for the second because you'll already have the gauge/coupler for the recharge.
2000 Mystique LS Duratec 2.5L MTX
Take it and have a shop put the fluourescent dye in and recharge it (only cost me $14 here). Then they can find if it has a leak. But why do you need a/c? You live in NJ.
Cool Toe Chris
Cool Toe Chris
It gets hot here. 'Nuff said. Yes, anything over 80F is hot here, compared to you southerners.
Chris NJ 98.5 SVT Silver Frost
Everytime he chims in on an A/C thread, it's always "you don't need A/C..." LOL, gotta love predictability!
That's because he removed his for weight savings (I think it was busted anyway) and he is used to it..
right?
Ray
Did you drive them during the fall/winter any? If you used the defroster that runs the AC compressor. That would be the same as using the AC as far as I know.
98 Contour V6 MTX, T-Red, 150k mi. Pic SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin 95 F-150 91 Mustang GT 06 Honda Shadow Aero
R_G Offline OP
Yup, the defroster was constantly in use.
Kremi and A/C - it used to be one of the CEG's favorite topics; then Ross went to college, ya know, teenage drinking, premature sex, mind altering substances so for some time he hasn't been toting his "Let's Do Away With A/C" philosophy; now Kremi is either off-campus or planning to, and we are again back to A/C discussion.
