#1290780 05/29/05 10:13 PM
sometimes when i drive long distances, the o/d light starts to blink and when i get back to the city and have to stop completely and then go again, it jerks when it shifts to the next gear.... what does this mean and how can i fix it???
1997 Contour LX (With 2.5L V6 Duratech)
#1290781 05/29/05 11:43 PM
Search in troubleshooting for "bang shift", as well as read the faq on contour.org's main page under "common problems" then "driveability"..
Also, a flashing O/D light can be scanned for codes, just like the CEL.. but I am not sure as to the life cycle of the code (not sure if it is "stored" like a typical CEL, or only for THAT particular start session...)
Ray
#1290782 05/30/05 12:54 AM
OD light flashes when internal slippage or overheated fluid (caused by slippage) is detected. It�s a good idea to get it looked at right away and keep your speed down to prevent additional damage.
A code scan can help pin point your problem.
jeff
have you fixed your ford lately?
#1290783 05/30/05 01:50 AM
Ray
Once you turn off the ignition, you lose the code. There is tons of info in the transaxle forum as well by searching for O/D light flashing. Also follow Ray's advise mentioned above.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1290784 05/31/05 01:38 AM
You won�t lose the code but the PCM will clear from limp home (full line pressure mode) by cycling the ignition. It takes several ignition cycles for the code to clear.
jeff
#1290785 05/31/05 05:22 AM
Ray
ok i searched in troubleshooting for "bang shift" and in the other forums, i just see u telling other peoples to search in troubleshooting for "bang shift" and look under the main page for driveability. i also see people talking about some 1744 problem, wut is that? and also wut do u mean by CEL, wut exactly is that? on the main page under faqs - common problems - driveability, there isnt anything about the "bang shift".
#1290786 05/31/05 05:43 AM
Wow.. you searched! that is unusual, so thank you.
Try looking up posts on the VSS (vehicle speed sensor) or TSS (Transmission Speed Sensor).
A faulty sensor is rather common and can cause the harsh shifting.
Ray
#1290787 05/31/05 06:03 AM
Ray
no.. thank you for the help... im searching for the tss and vss rite now and a lot of things showed up. and also, u never said wut the CEL was.
#1290788 05/31/05 06:07 AM
CEL.. Check Engine Light..
Ray
#1290789 05/31/05 06:25 AM
oh ok, yea my CEL is also on and i got the codes pulled at autozone. the codes are P0420 and P0133
