Well what I did because my KKM was not the SVT model with the attachment that goes to the fender, I just took a 3.5" piece of ABC pipe that had the inside part threaded, cut it so I ended up with a 1" ring that was threaded on the inside, glued this to the end of the KKM over the opening on the end. I then took 3" aluminum dryer hose and threaded it into the piece that was glued in, then extended the other end into the stock fender snout and clamped it.
I'm hopeing that when the filter is pulling in air, its pulling some from the inverted cone part on the end, thus pulling a little cool air from the fender. I also notice the car is pretty freakin loud now with the open air and having the exhaust and Ypipe done (I had only run the stock airbox since having the exhaust until last night).
I think I've gained a bit of throttle response vs the stock airbox, lost a bit of bottom end torque but gained some after the secondaries open. I have not had much time to drive and let it really get heatsoak...
