Page 2 of 2 1 2
If it pulls when you are not on the brakes, it is not a brake pull. It would be a tire or alignment problem.
so a tire or alignment got all out of whack when i installed ss brake lines? it drove perfect before i installed them, which is why i HIGHLY doubt it's alignment or a tire.
OK, sort it out. It is very unlikely that you have a brake problem if it pulls when you are not braking. There is only so much diagnosis help that can be given without inspecting the car.
I do care to know what you eventually find.
well it's got to be something with the brakes, logically, otherwise is one [censored] crazy coincidence..
before we installed the ss lines and front right caliper, the car drove perfectly straight... after we installed them, the car pulled to the right, so OBVIOUSLY it's something with the brakes. thus, it is VERY LIKELY that it is a brake problem.. im just trying to get some ideas on what it could be.
Page 2 of 2 1 2
