#1288963 05/26/05 07:58 PM
I've recently pulled and re-installed the engine (did not get inside the engine though) and relocated my battery. Yeasterday before work I turned the key and it won't start. The very first thing I noticed was that the fuel pump did not come on in the KOEO position. I checked my fuses and found F9 to be blown. Replacing it has done nothing. I've got all lights, radio, door chime, even a/c with KOEO. Just don't have fuel pump. With KOEO, I unplugged the fuel pump and used my digital multimeter to find that I've got 8 volts running to the plug on top the fuel pump. However, I don't really know how to interpret this. I tried referencing my Haynes manual and AllData and can't find anything.
Can anyone tell what's going on with the above info or tell me what I should check next? I'd really like to get on the road again.
Thanks,
Randy
#1288964 05/26/05 08:06 PM
Oh yeah, I've also checked the fuel cutoff switch.
#1288965 05/27/05 08:27 PM
Make, model, and year would help. The voltage readings would be different with a return fuel system vs a returnless system.
#1288966 05/27/05 09:44 PM
Hi Jim,
Please check my post "Possible Wiring Harness Issue" here in the Troubleshooting forum (I'd link to it but don't know how). I think I've discovered it to be more than just a bad fuel pump. Your thoughts are appreciated.
Randy
