Posts: 1,336 |
Originally posted by todB-A-N-A-N-A-Sras: Originally posted by fastcougar:
Anyone heard of a spun bearing with less than 20,000 miles on the engine?
<-------- 50.
50 miles on brand new rods? or 50 miles on a rebuild engine with reused old rods? I should have asked: Anyone heard of a spun bearing with less than 20,000 miles on the rods?
Posts: 6,760 |
the latter IIRC. Originally posted by fastcougar: Originally posted by todB-A-N-A-N-A-Sras: Originally posted by fastcougar:
<-------- 50.
Ryan
Trollin!
Posts: 10,015 |
Yeah becuase you didn't prime the oil pump and dead crank your engine first! Starting a new, dry engine and having it instatly rev to 3500rpms USUALLY fuggs things up!  Your data-point is null and void!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 6,760 |
That's what engine lub is for stazi, duh! I kid, I kid :-) Originally posted by Stazi: Yeah becuase you didn't prime the oil pump and dead crank your engine first! Starting a new, dry engine and having it instatly rev to 3500rpms USUALLY fuggs things up!
Ryan
Trollin!
Posts: 10,015 |
LMAO: Whenever I see that "I kid, I kid" I just think of EuroTour or Todras saying it and it cracks me up.
AUSSIE ENDLINKS $70
Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 2,097 |
The whole point about if it were an oiling issue...would cause bearings to fail driving it home is not correct. Think about... We aren't talking about the crank, rods, and bearings sitting in a dry position...it's an occasional loss of lubrication that causes the problem over time. Many right hand turns, draining issue on high rpms. It doesn't happen all at once. Just like a bearing will wear down and then spin. You can run your motor for a while with low oil before it will actually break.
How can someone completely discount an oiling problem? Just because it doesn't happen the second you start the car?
98 E0 SVT with some stuff
Posts: 4,777 |
mine was CLEARLY an oiling issue.
Posts: 5,810 |
Originally posted by Russell-3L: got a spec slave cyl sitting on the shelf, and a brand new ford one in my car
im curious to see how my spec stage 3 clutch looks like after 2500 miles on it (i learned to drive stick on this car with nobody teaching me)
I've been using the Spec slave cylinder that came with my clutch, two years this may. I pulled it all out last year and examined everything when I did the mods to my turbo manifolds and I had no issues. Maybe not all the spec slaves are bad.
See My Mods
Posts: 5,810 |
All metals have elasticity to some degree, however; the powder metal rods are likely to have less flex than a comparable forged rod. VERY VERY unlikely that it is stretch. I would to think that if the bearing spun then the oil film got too thin at some point for some reason. It could be the clearance was too wide for the oil feed, it could have been air, it could have been that the clearance was too tight for the oil viscosity used. What about the pistons? Do they have a moly coating? Is there any side thrust that can cause the rods to press a little to hard laterally? You see there may not be only one right answer.
See My Mods
