Posts: 5,810 |
It doesn't prove that at all! I had 2.5L heads on my 3L for over two years without a problem. In my opinion its that fuggin 0w and 5w oils that allow it to spin. I have never run thinner than a 10w-30 oil and usually run a 10w-40 oil, and even run 20w50 on the non-turbo engine form in deep summer. I've abused my engines all times of the year as much as anyone and I've yet to spin a bearing. I am really starting to think it is the oil viscosity and the tight clearances on these engines.
See My Mods
Posts: 1,336 |
Russell,
Do me a favor and take pictures of the crank, where the rods bolt to the crank journals. You should be able to see the culprit the minute you drop the pan. Remove the offending rod/piston and then bolt the cap back on the rod and measure ... I'd bet $100 that the journal opening is oval (out-of-round).
Posts: 3,570 |
Originally posted by Roz 1999 SVT-C: Might want to compare your 2.5 liter oil pan to a 3 liter oil pan out of a 2003 escape.....Thats the one i used for my 3 liter hybrid....Im running the same set up as the motor you blew, only i kept the stock 3 liter pistons (only 5000 miles) and bearings....And i used the 3 liter oil pan. ... I ahve 17000 miles on this motor now.. .All are HARD miles...no problems.
Ditto. Only I have closer to 21,000 miles. All stock block parts, 3L pan, 2.5L SVT heads, no problems, driven HARD.
Posts: 6,106 |
Originally posted by warmonger: It doesn't prove that at all! I had 2.5L heads on my 3L for over two years without a problem. In my opinion its that fuggin 0w and 5w oils that allow it to spin. I have never run thinner than a 10w-30 oil and usually run a 10w-40 oil, and even run 20w50 on the non-turbo engine form in deep summer. I've abused my engines all times of the year as much as anyone and I've yet to spin a bearing. I am really starting to think it is the oil viscosity and the tight clearances on these engines.
29k miles on my Hybrid. 2.5L oil pan. 5w30 Mobil 1 Full Synthetic. 2000 3L had 11k miles when I picked it up, and clevite rod bearings were swapped in for the stock units. I'm now finding out how this motor likes nitrous
Mark
2000 Black CSVT
Posts: 1,238 |
Damn. Nice numbers. What shot are you running with the Venom? -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 10,015 |
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 55 |
What was the measured rod bearing clearance? How about the rod itself - were the ends measured? Was rod side clearance checked? In fact, there are numerous measurement which need to be taken/verfied when doing a rebuild. Possibly these were all checked, however wanted to ask up front.......
Posts: 976 |
How were you driving when she let loose?
That sucks man, I may be interested in a trade for your heads if that would help you out at all.
Posts: 390 |
Posts: 21,197 |
Originally posted by rkneeshaw3.0: 3L pan,
No you don't!
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
