W
W
Hello,
I have a 98 Contour, 2.5L Duratec engine. Over the past year or so I have been having the same issue repeatedly. Most times I can get my car to start without any problems. Recently, my car has been having a lot of trouble starting. When I turn the key, I usually get a puttering sound like it is trying to start, or like an old man is coughing under my hood, but then it never starts. If it does start, I have to continuously press the gas to keep if rom dying. I used to be able to hear the fuel pump charge up when I first turned the key prior to ignition. Now I don't. I am at a loss. I have had an oil change recently as well as replacing my air filter. Could someone help me? And if it is a fuel pump issue, is there any thing I can do to cut the costs? Any help would be greatly appreciated.
E
E
Try replacing fuel filter first. Real easy job.If that doesnt help at all, it's more than likely fuel pump. Mine used to have problems starting in cold weather and then i replaced fuel filter and it started every time.
1998 E0 T-Red SVT #1223 of 1653 OLD CARS -1995 Thunderbird 4.6 V8 -1984 Porsche 944 (rustbucket)
how old is your battery? Here in Florida they usually last about 4 years before needing a replacement. Stop by an AutoZone or other auto parts store that offers a free charging system check. They'll let you know what the weak link is.
It might be as simple as cleaning the battery terminals...
W
W
Thanks Esmizzle and TourDeForce,
I'll try the fuel filter option and let you know how it goes.
As for my battery, it is brand new by a week but the connectors to the post on my battery are corroded. Is there a way to clean this or will I need to replace those as well?
Thanks again
Thanks again
Recently mine we're making terrible connections. I could only make a decent connection with the clamp fully tightened.
I unhooked both terminals and sanded down the surfaces on both the cables and the battery. Works perfect now.
