Posts: 46 |
There seems to be some moisture in my headlights. I can not find where the seal is broken at all. I went all around the headlights, and couldnt find where it was getting in. Is there a way to fix it, or am i gonna have to buy a new set of headlights?
Thanx Brian
1999 SVT Contour
Magnaflow Dual Exhaust
KKM High Flow Intake
Posts: 6,700 |
Here Here and Here Amongst MANY other discussion about this very COMMON problem. Use the search fucntion of even the stickies on top of the froumns for almost ALL of the info you need. Welcome!!
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 46 |
1999 SVT Contour
Posts: 3,867 |
Wow. Three links, all full of BS.
What year is your car? That would help. The pre 98's are different than the 98+
Function before fashion.
'96 Contour SE
Posts: 6,700 |
Uhh... he's already taken care of?? and his is a 99 CSVT. The links, one in particular show exactly his three options. Reseal them by pulling them apart and then de-hazing them, deal with it, or buy new ones. There is nothing more to that.
Posts: 3,867 |
Originally posted by ElStry-pedBanana: Originally posted by RogerB: Wow. Three links, all full of BS.
The first link is to a post about fixing hazed headlights. Not moisture.
The second link includes no useful info, and some BS about drilling pre-98 headlights. Also a link to the de-hazing FAQ. Again, wrong problem.
The last link contains this bit of misinformation: "...this (condensation) will also cause yellowing and hazing, which inturn you will have to fix with a good plastic polish to remove and wet sand."
The same person also says that the seals on the headlight assembly are bad. (Correct) There's also a bit about cleaning them and resealing. (Also correct) So I take back my claim that it's all BS.
But, geesh, in the time it took you to search and post those three links, (2/3 of which were useless) you could have answered.
Worse, the misinformation is propogated, and bound to be passed on to the next round of newbies.
So, let's clear this up:
1. Condensation on the inside does not cause yellowing on the outside. Likewise, polishing the outside of your headlights will not cure water damage to the inside.
2. Pre-98 headlight assemblies are vented. If seals are bad, they might collect more water than usual, but a little condensation is normal under certain weather conditions. If water gets in but can't get out, check the vents first. They are little white "buttons" on the back of the housing, near the upper-outside corner of each housing. I tried sealing and such, and had no success until I figured out the vent was clogged. By then the headlight was ruined by water damage. Post 98s are different, obviously. I think the clear lens is easier to remove, and they are not vented.
'96 Contour SE
Posts: 980 |
Originally posted by RogerB: If water gets in but can't get out, check the vents first. They are little white "buttons" on the back of the housing, near the upper-outside corner of each housing.
I looked and couldn't find it, do you have a picture?
2000 Mystique LS
Duratec 2.5L MTX
Posts: 3,867 |
I don't have a picture, but I'll try to find one. I'm not sure at all about Mystique headlights, though.
'96 Contour SE
Posts: 3,065 |
Originally posted by RogerB: 2. Pre-98 headlight assemblies are vented. If seals are bad, they might collect more water than usual, but a little condensation is normal under certain weather conditions. If water gets in but can't get out, check the vents first. They are little white "buttons" on the back of the housing, near the upper-outside corner of each housing. I tried sealing and such, and had no success until I figured out the vent was clogged. By then the headlight was ruined by water damage. Post 98s are different, obviously. I think the clear lens is easier to remove, and they are not vented.
The post 98s are vented. They have little hoses on the back. Tisby, if you can't find the button, it is most likely because you have post 98. If your lights are rectangular and have straight edges, they are pre 98. Rounder and curvyer are post 98. The lens on post 98s need to be cut open w/ a dremel. Try checking the seals and o-rings where the bulb goes in and see if that is the problem. Otherwise, go over the whole bulb w/ silicone sealent.
Posts: 980 |
Nope, it's def. pre98, as in 1996, as seen in my sig.  Anyway, a pic. of the pre98s would help...
2000 Mystique LS
Duratec 2.5L MTX
