Posts: 7,025 |
I guess the graph explains it all.
The 364 whp run was made on 16 psi and was cut short at 4,700 rpms since it hit 13:1 air/fuel. I think if we could have taken it up to redline, it would have been a 400 whp run easily.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
CEG road warrior
CEG road warrior
Posts: 17,248 |
Your car is insane!!!!  X10000000000000000000000000
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,194 |
Thats some serious torque! Glad to see its up and running.
Posts: 2,978 |
I think that graph officially makes you the winner at the contour game...
Posts: 4,760 |
You guys had to see this thing, Its a beast.
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
Posts: 4,713 |
First off, awesome!
I have questions (the graph didn't explain everything...  ):
1) Why'd you shut it down before 6500?
2) What were the boost levels at for these runs? I'm guessing that run #2 was too much boost for the fuel?
Congrats, Jim. That thing's a beast!
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 7,025 |
I have a base tune for 8 psi. As you could probably expect, doubling the psi might cause the air/fuel to flucuate a bit, which it did. As soon as it hit 13:1 air/fuel, Phil stopped the run.
Jim Hahn
Posts: 4,713 |
Is your rev limiter set for 6300?
Derek
Scion xB 5-spd
Posts: 7,025 |
nope, its the stock rev limiter, 6750 i think. But since power starts dropping off around 6,000 i figured why not take the motor higher than it has to. I just told Phil to stop the pulls at 6,300 rpms.
Jim Hahn
Posts: 4,713 |
Understood.  So when are you going to get the fuel set up for 16 psi?  Again, great job, Jim.
Derek
Scion xB 5-spd
