No replies so I thought I'd share how to remove and install it. First off, no special tools required. Remove the two small screws at each end of the bracket holding the bottom of the condenser. Lift the condenser to unhook the two side brackets and let it down a bit. Remove the two 13 MM nuts from the inlet and outlet fittings. Drop the condenser out. Reverse to install, but replace the two "O" rings. Was easy. My Ford manual says the radiator, condenser and fan come out as a unit. That would not have been easy:)
Al
2000 SE Sport, V6, 5 speed
