Posts: 101 |
i am curious. what is the stock flow rate in lph or GPH?
1998 SVT
2.5" exhaust to 2.25" duals, homemade intake, 94A poly RRR, B&G Autobahn Series Springs
Posts: 2,017 |
Wow I searched and found this in the archives. Took 2 minutes. fuel pump specs
1996 2.5LT V6 Contour ATX My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Posts: 101 |
that told me which pump to use...  not so much. i hate to do this, but what would the part # be for an upgraded fuel pump? will a mustang pump fit? if so, thats cheaper.
1998 SVT
Posts: 1,238 |
Focus pump PN 3S4Z-9H307-BC. HTH -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 2,017 |
Originally posted by cavrs: that told me which pump to use...
Don't roll your eyes at me!
You asked and I quote:Originally posted by cavrs: i am curious. what is the stock flow rate in lph or GPH?
That's what I gave you. I answered your question.
Now if you wanted to know what would be a good replacement fuel pump then maybe next time state that.
Something like: What's the best replacement part for _______.
Posts: 9,602 |
Originally posted by tropictour: Focus pump PN 3S4Z-9H307-BC.
Returnless only.
Return style can use a Walbro Mustang pump.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 5,810 |
Yeah,
I dropped in a 255lph Walbro and it is a noisy, whiny bi-atch whenever the fuel drops below 1/3. However, it has never faltered and so far run flawlessly. At the first sign of the pump whine I checked the fuel pressure with a gauge and found it was being regulated correctly by the stock fuel pressure regulator at idle and off-idle. Therefore the whine is just the way the pump is, not because it is straining.
FYI, I used the stock pump to set down 300 wHP. I ran it at least 15 runs or more on the dyno and the Air Fuel showed that right at the top, 6000+ rpm the mixture was getting a tad leaner. It was still safe, a little over 12:1 at those high rpm. I tried to add fuel but it would not richen up, an indicator that the pump was maxed out... or injectors but they were 36# injectors and were not near max duty cycle. With just a pump change everything richened up and I had to readjust my A/F later.
Bottom line:
If you aren't pulling close to 300 wHP, don't worry about an upgraded pump! The stock pump is more than sufficient for anything short of a "built" 2.5L turbo or a 3L turbo.
See My Mods
Posts: 101 |
thanks warmonger! i love the info! so a stock pump flows enough for a dry kit?
1998 SVT
Posts: 5,810 |
My car is a return style, but from my experience I would say it has plenty of fuel in it for a dry kit or another 100 HP.
See My Mods
Posts: 710 |
Originally posted by warmonger:
Bottom line:
unless his stock pump is going... then the Focus SVT pump is cheaper than his stock pump. I just had to get a new one... and I got the fsvt one from Bill at $77. I believe he said the CSVT one was around $120.
morbid
2000 Contour SVT (black)
