Page 2 of 3 1 2 3
i'd put them in the panels that are already in the interior (maybe even behind them, and install a couple cooling fans). or, maybe create a false floor to put them in.
TGO Offline OP
behind the existing panels is not an option. There simply is no room behind them. Maybe, MAYBE for a small 2 channel for the sub, nothing more. On the left hand side you have the control computer for the 4WD system, on the right is the stock smplifier, which will be removed but still doesn't look promising. And that still leaves me with no space for a 4 channel.
False floor is a possibility, however, it'll make the back area higher than the rest when the seats are down...
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
you could also mount them above those wheelwells.
TGO Offline OP
Yeah, but again, i'd be worried about stuff sliding around and crashing into them. I carry lots of boxes, buckets tools, tool boxes, ladders even...If i mount them there, i'd have to build some sort of box around them and that = less space for me to carry what i have to carry.
The only other solutino i could think of is tint the back windows completely black, cut/mount some wood there and use that. It's alot more work, and i'd prefer not to lose the visibility as well.
Floor space is very important for me.
i would think a mdf or plywood amp rack would protect it well and add no more than 1" to the depth.
TGO Offline OP
amp rack? are you talking mounting them horizontally or vertically?
vertically.
Captain Impound Boy
Captain Impound Boy
how about under the car? suspeded from like the gas tank? that would be a stealth install
Mount to the rear of the front seats?
Previous Owner of 00 SVT Contour #1077/2150 95 Contour SE '01 3L
Page 2 of 3 1 2 3
Moderated by  dnewma04_dup1
