Posts: 47 |
I have used the search button but still couldnt find what injectors i can use in place of the stock svt injectors. i just want something alittle bigger
#510 of 2760, KKM true rev induction, optimized y pipe, exhaust,custom tuned Diablo chip, and BAT lowering springs, DMD, optimized throttle body.
Posts: 1,860 |
Why do you want something a little bigger?
2001 Lincoln LS8
1994 Lexus GS300
Posts: 47 |
just a thought for running nitrous
Posts: 10,015 |
Not necessary.
If you go up to 24lb'ers it'll throw codes everywhere and idle like shiz. You DON'T need them
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
any injector change needs to be accompanied by the proper computer tuning changes to accomodate them correctly.
Posts: 47 |
ok. thanks. when i put in the nitrous im also putting in a SAFC 2 for the tuning. but if i dont need them thats great
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
SAFC 1 or 2 will not properly accomodate an injector change.
Posts: 10,015 |
Seeing as it is a 126% bigger injector you'd have to tune down the SAFC at least 26% across the board from idle and taper it off with increasing revs, but in all reality I don't think it's worth bothering with.
AUSSIE ENDLINKS $70
Posts: 47 |
thanks. i just want to make sure that i wasnt going to run lean when running the 50 shot
Posts: 5,810 |
Use a wet kit...but be careful you don't get the cheapo kit, or if you do that you get some extra's for it like fuel pressure switch and bottle heater. These kits will add the fuel and Nitrous with a nozzle that you can install right before or after the throttle plate. You can tap the fuel source right off the schraeder valve on the fuel rail. This totally bypasses the need to alter you injectors or fuel system. I wouldn't run more than a 75 shot with it though since you won't be pulling any timing.
See My Mods
