Posts: 1,786 |
That looks like the correct place to cut. Just make sure you cut until you see white powdery stuff. That is the glue that holds the lens in place. After that, pry off the black plastic with a slot screwdriver all the way around. The next part is HARD, you need to SLOWLY pry off the lens all the way around. Don't rush it because you can end up with a split lens. Also, make sure the lens isn't cool, or cold. That can cause the lens to snap, also.
Good luck!
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 5,621 |
Originally posted by unisys12: and the almost three months since I have put any Meguiar's Clear Plastic Polish on them.
Never worked for me.
Posts: 4,051 |
Originally posted by R_G: Originally posted by unisys12: and the almost three months since I have put any Meguiar's Clear Plastic Polish on them.
Wet sand them first. I've done headlights for a SVT and an Accord. Both came out beautiful.
Posts: 1,016 |
That's exactly where I cut mine. I've notices that others said they cut right where the clear and black meet. I do NOT recommend that. Yes it'll work, cause obviously it did for them. However, if you cut where you have marded, it'll make sealing them so much easier. The clear plasit is sandwiched by the black, so if you cut where you have indicated, you can remove the top piece of the "sandwich", then cut the clear (if needed) and break the seal from the clear and the bottom piece of plastic. When it comes time to re-seal, just glue ontop the glue, then silicone. Since you'll have removed the top piece of plasitic there will be an obvious void that needs filled, and you're done. If you need more clarification, do not hesitate to PM me.
~Eric
2000 CSVT Silver Frost: #942 of 2150
HID Projectors and Fog Light Mod, Optomized TB, MSDS headers
2003 Silverstone Z
Posts: 158 |
What kind of glue did you guys use to seal them?
98 SVT
18" Enkei RS6's, NITTO 555 Extremes
Intrax lowering springs
K&N filter
Sho-Shop Y pipe (without cats)
Stock "gutted" manifolds
Carbon Fiber Cowl hood
Carbon fiber sail panels
Posts: 3,944 |
Originally posted by svttour2002: What kind of glue did you guys use to seal them?
I think I am going to go a little different route than what I have read most have. Most people just us black RTV to seal them, but I am gonna try to lay a small bead of the black RTV on the edge of each section. Let them dry and butt them together. Then use tie large tie wraps to secure the two sides. Finally, after the black RTV has set, I am going to go over the cut section and fill in with clear flowable silicone. This should seal up any tiny areas that do not seal.
It all sounds good in theory, so let's see if it works.
Thanks for all the input guys. I will be sure to take plenty of pics while I am doing this.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 3,195 |
These were my instructions I posted quite a while back, it looks like the line you drew was right about where I cut:
I used the cut-off wheel & cut about a 1/4" strip from where the lense overlaps the black housing...in turn, peeling the cut edge of the lense as I went along, then cutting through the rest of the housing, prying (carefully)until they became separated. I removed the top rubber strip by dremeling the plastic welds before cutting.
Sooo...when I put the housings back together I had a nice channel to glue. I taped them w/ 2 pcs of tape & used JB Weld (I did one side & let it dry overnight, then flipped them over & did the other side...of course touching-up the tape spots too). I put the two parts of the JB Weld into a baggy (cut-off a good sized corner...like a piping bag (see your mom if you need help w/ this step )) I then squished both parts together until mixed, squeezed the mix into the corner of the bag & cut-off a very small bit of the tip. This allowed me to "pipe" the mixture into the channel between the two halves & it flowed very nicely. I am still going to smooth a little silicone over the welds, although they look too pretty to cover up .
1999 Sportage 4x4...don't go there, it was free
....______o_o
.../_l l__\____\
..|--l l__----[]\|/[]
.....................oo
=( )_)----( )_)--)_)
Posts: 1,016 |
I bought some two part clear epoxy from Auto Zone and glued spots every 2-3 inches, and used clamping belts (normally used for wood projects) to secure things tightly together. Then ran a beed of black silicone around the cut area, and done. Not a problem yet. Even through that terrible storm here in OH this past fri.
~Eric
2003 Silverstone Z
CEG road warrior
CEG road warrior
Posts: 17,248 |
I used plastic weld and then black RTV ALL THE WAY AROUND.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 158 |
Awesome. That is what I just bought and it looks like that is my new weekend project since I got some practice last night with some old headlights that were just laying around are hazed real bad. Thanks guys I think this will look awesome with the hood.
98 SVT
K&N filter
