Page 1 of 3 1 2 3
#1276481 05/13/05 06:16 PM
9
95tour Offline OP
Hello everyone did you all know that roush performance has a new turbo kit for the focus. 99-03 with the 2.0 z-tech engine. Boost horsepower by 95%. kit includes intake manifold, cold air induction and all necessary hardware for complete install. wonder if that will go on our cars as well? if they are the same.
#1276482 05/13/05 06:59 PM
I
I
i have seen that kit beeing talked about on FJ many times. For the price you might as well build your own since you don't even know if its gonna fit 100%. I know I'm not about to test fit a $4K kit.
#1276483 05/13/05 09:49 PM
The problem with buying a Focus kit is that none of the intercooler piping or tuning will work. Possibly not even the intercooler.
I don't know about you, buy I REALLY don't want a 1500 degree turbo 1/2" from my hood.
If you could get it without the piping, chip, and intercooler, it might be worth it. That would make it reasonable at $2k.
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
#1276484 05/14/05 05:12 AM
TjZ Offline
What kinda numbers are the FJ people getting with this kit?
Also yeah I think for 4k I would rather make my own custom kit, but hey if it works hmm..
#1276485 05/14/05 06:03 AM
9
IMO the entire layout of that turbo isn't setup for optimal performance. For example the intake piping that first runs beside the exhaust pipe to the intercooler, then from the intercooler to the throttle body over the valve cover, then the intake filter placed inside the hot engine bay. That all adds up to even hotter intake air, which could have been reduced a lot running a different piping layout.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
#1276486 05/14/05 06:37 AM
CEG road warrior
CEG road warrior
It is a optimal layout if you want to keep your battery under the hood.
#1276487 05/14/05 07:16 AM
It keeps stock battery placement, rougly stock MAF placement and more importantly, stock CAT placement. It won't work for our cars, cause our CATs are different. The Focus has a 3 bolt flange that looks kind of like a standard header flange. Our flange is a big squaure 4 bolt thing.
Not worth it, IMHO.
2000 Rio Red I4 Cougar 200whp & 210wtq at 9psi 254whp & 276wtq with NX 35shot WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
#1276488 05/14/05 03:24 PM
The only kit I would consider dropping $4k on is the Demon Dynamics kit.
Otherwise spend less than $2k and build a custom kit and spend another $500 on a custom tune.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
#1276489 05/14/05 07:52 PM
AMEN!
#1276490 05/14/05 08:09 PM
TjZ Offline
Demon Dynamics kit, speaking of which I tried going to there site and it was down. What are specs of this kit and are there any dyno's out of it?
Page 1 of 3 1 2 3
Moderated by  Loco4G63
