got a 96 contour, 2.5 engine... the coolant tank's sensor is not registering that it is full.. i know about the add one cup of extra coolant.... the problem is that the sensor is not working.. i got alot of extra coolant in there... how do you remove the sensor to clean it or replace it with a new one? thanks for a reply.....
If I recall correctly, you need to empty the tank, unbolt the tank and it's located underneath, just pull it out. It's been a year since I pulled mine out so I can't remember the whole thing properly.
