#1274703 05/11/05 06:21 PM
rudolfo Offline OP
I just read from a webpage saying that adding some ATF into
the gas tank will improve the gas mileage. Because the ATF
will help clean the engine and lube the fuel pump.
it that true ? just wondering
#1274704 05/11/05 07:20 PM
Umm the gas tank! NO! It is fine to add some to your oil. It will act as a detergent cleaning valve deposits etc. I wouldn't run it long before doing an oil change.
#1274705 05/11/05 08:53 PM
I 2nd what todras just said. Never in the gas, but yeah exactly as he said it has some detergents in it which will clean off some buildup in the engine. When I had my FD I would run some every so often to help fight buildup. Although it's a bit different in a rotary engine as by design they burn oil (it's injected into the combustion chamber), but the effect is all the same on a piston engine.
Ben *now* '00 CSVT T-red/tan #1684/2150 *sold* '92 Galant VR-4 #580/1000 *sold* '93 FD3S TT
#1274706 05/11/05 11:38 PM
E
E
if you want stuff to go in your gas tank, get seafoam....then you can also throw some in your crank case as well.
95 SE MTX svt exhaust intake deer killer
#1274707 05/12/05 06:22 PM
rudolfo Offline OP
Ok, I see. Thanks .
#1274708 05/12/05 06:24 PM
i don't think it's a good idea - it can kill oxygen sensors\catalyst.
Kirill 98.5 Silver Frost Contour SE Sport (powered by Duratec) traded for 01 Audi A6 2.7T in September 04. Some stuff for sale in classifiends: http://www.contour.org/classifieds/classifieds.php?t=1&c=1
#1274709 05/13/05 01:50 AM
E
E
are you talking about ATF or seafoam in the tank?
#1274710 05/13/05 05:16 AM
Around 500 miles? Or less, say 50-100?
2000 Mystique LS Duratec 2.5L MTX
#1274711 05/13/05 05:47 AM
i think he meant atf...only thing seafoam will do if added to your tank is make your car run better..
new,new ride! '99 svt black/mnb '95 mustang gt sold! '98 svt #800 sold!
