I have a '98 contour v6 mtx.. Started to change the spark plugs today and quit before I got the first one out. I did disconnect the ignition coil electrical connector, but neglected to disconnect the spark plug wires from the ignition coil. I also forgot to disconnect the variable intake system actuator electrical connector. I had just popped off the cap for the first plug when I decided I didn't have enough time to finish. I put everything back together, start my car, and it has a very rough idle and struggles not to stall. I dont even think I can drive it to my mechanic. I tried disconnecting my battery but no luck with that.
Would appreciate any ideas or thoughts you might have.
Kevin
