Page 2 of 2 1 2
I just checked Autozone. Front Timken wheel bearing is $42.99.
When I took mine to machine shop he charged me $20.00 for each bearing to press out and in.
Total cost if you do it yourself is about $65.00!!!
Bob
Although Ray is right you can do it, it is not really a trivial job. The one part you can not readily do is press the bearing back in. I just had both bearings done for $400 from the dealer. I decided that the time was not worth the dollars and to buy the hubs with the bearings was only saving me $80. Again that was not worth the effort.
Rich S
1998 SVT 1995 Contour 2.5 MTX 215K miles Son's car(dead and buried) 1997 Contour 2.0 ATX 1998 Contour 2.5 ATX 2004 Tauras Wagon 3.0 Duratec
If you like the car,stick it out. If not,dump it. That's what I did with my Mystique. It was a nice car,but it was giving me all sorts of problems and it was a 4 cyl and automatic which was a POS,so I dumped it for a '95 Contour with a V6 and 5 speed. I'm much happier now,but....
=...it cost me $1600 to get it roadworthy. However,the Mystique would have needed just over $2k to keep it roadworthy.The Contour needed new struts and springs on the rear,rear brakes,e-brake cable,both lower ball joints and a 3rd brake light. I still need to get my tranny rebuilt because it grinds in 3rd gear as the synchros are worn out. Plus,the car has 262 000km on the original engine,but the body is in mint condition. There is not a speck of rust anywhere. I guess it helps the car was repainted in '99 after hitting a deer. lol
So,$1100 in 5 weeks isn't bad compared to $1600 in one day.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's '89 Mazda B2200 - Under Construction
Page 2 of 2 1 2
