#1272779 05/10/05 01:26 AM
2.0 zetec... fuel problems... little bit of oil dissapears every so often...CEL for bank one too lean... changed the o2 on bank 1, replaced maf and same damn cel... anyway this is what my plugs look like.. any idea what it could be??
http://community.webshots.com/album/342343796rTarrk?727
-Mike 96GL 2.0 Zetec CTA Intake SVT Exhaust
#1272780 05/10/05 01:46 AM
To me the plug looks pretty good, it is a tad on the white side which means its running too hot. So you could try a hotter plug. But honesty it looks good to me.
Andy
#1272781 05/10/05 02:04 AM
they are only a month old and there's all that carbon on it.. I suppose I should say I already cleaned it before that pic... that's NORMAL after a month? and they are motocraft...what would be a "hotter" one.. I used to use autolite but I got the same performance really so what do you suggest?
#1272782 05/10/05 03:45 AM
Change your brand of fuel. Those are fuel modifier deposits from certain fuel additives. It probably doesn't hurt anything but I would rather use fuel that didn't do that.
#1272783 05/12/05 03:01 AM
I run mobil 89 octain... suggestions? I used to use hess, but my ex girlfriends father knew a lot about cars and he told me about mobil using better gas blah blah. so what do you, masters of the ceg, suggest?
#1272784 05/12/05 03:05 AM
Is that carbon or oil buildup?
#1272785 05/12/05 03:08 AM
Here's a good read on spark plugs.
Click here
98 Contour GL/03 ZX3 Focus/05 ZX3 SES Focus
#1272786 05/12/05 04:08 AM
That is a good article and those are good illistrations. However the pictures only show the effects of heat range. It doesn't show the effects of various types of fouling. Such illustrations used to be common and could be found in nearly any spark p;lug catalog. They seem to be hard to find these days. The pictures you posted show classic "modifier" additive deposits. Some brands in certain areas seemed to have more such additives than others. In my area, Mobil doesn't seem to use such additives, at least not in quantities to do that. Just try some other brands and see what happens.
#1272787 05/12/05 04:27 AM
Look on the back of any Haynes manual. They have good color pics and explinations of spark plugs, and how to use them to read your engine.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
