Page 5 of 6 1 2 3 4 5 6
9
OK wow it actually mounts to the transmission on the vortec. Thats too bad considering the numbers the vortec puts out. Thanks for explaining it to me
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Having never made it this far into cars.
(Right over my head)
Originally posted by TronX:
So what do you think is better for the Zetec-ATX, Turbo or SC?
Because the ATX doesn't like lots of torque, a SC is the safest.
With proper turbo sizing, or with the aid of a boost controller, a turbo can be used sucessfully with an ATX. The main problem is that most of the turbos chosen for the Zetec build full boost by 2k rpms. With that kind of torque spike, the ATX will blow up pretty quick.
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
there comes a point where if your getting so seriously into it with seriously considering a turbo - where you should consider selling up if you've got a ATX car and buy a MTX. even if you've already done alot of mods, most can be removed fairly easily and transferred to the manual car. would work out alot easier than a ATX to MTX conversion.
back on topic - the JRSC is now all getting swapped over from the dummy engine onto my real engine. turns out i didnt need any engine mount mods, and he put a 5mm spacer between the S/C and inlet manifold to overcome the alternator problem. this means i keep the original alterator. its turned out alot more simpler than i expected but because of the research that he's put in it'll cost me a bit extra - me being the guinea pig lol! i'll make sure all the details of the conversion gets put on all the main zetec websites (and my own website which is well up the google ratings) to save any future people wanting to do this conversion the hassle of researching it. also i'll get it in fast ford mag for more publicity.
Now I can keep an eye on you here as well, perce
200 Estate, 220 engine built and ready to fit, someone give me the time to swap them!!!! Alloy 220 inlets for sale, pm me.
CEG road warrior
CEG road warrior
BP
The exact reason I went with the JRSC. My boost is regulated by a pulley.
Originally posted by LoCoZsc:
My car is for SALE!!! $5500 OBO
May part out- PM me if interested in parts
Say it ain't so?
Are you being drawn over to the dark side?
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
CEG road warrior
CEG road warrior
Say it ain't so?
No....you'll see soon.
I'm guessing that somebody bought a MTX.
PMSL @ Puzzle!
Moderated by  Loco4G63
