Page 4 of 6 1 2 3 4 5 6
Not really sure but most FWD ATX's are weaker than their MTX counterparts on the same type of car.
If you want a beefy ATX, get one from http://www.lentechautomatics.com/
There's a Focus pushing 500+ whp on one of those.
98 Contour GL/03 ZX3 Focus/05 ZX3 SES Focus
Originally posted by microtonal:
I know with the FS Vortech SC, you need to relocate the coolant resevoir and move some other parts around to make it fit. As you can see, it's a very tight fit to get the SC to fit on the belted side of the engine.
The main problem of putting the Vortech SC on a Contour is the passenger side motor mount. We have a big-ass cast iron bracket that goes around the side/front/back of the engine. The Foci use a small bracket that come out the middle of the timing belt cover. If you could somehow get the Focus motor mount into a Contour, then I'm sure you could use any of the Focus kits.
Originally posted by johnwilliams474:
has ANY BODY JUST PUT A STRAIGHT UP TURBO SETUP ON THE ZETEC CONTOUR sorry damn caplock key
96mercury is working on one and I am working on another. 96mercury will probably have his done months before mine. I am currently out of cash.
Percy, I feel sorry for you. The newbies have hiijacked your thread.
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
CEG road warrior
CEG road warrior
The reason I couldn't use the Vortec is because I have an ATX. The Vortec was fabricated for the MTX.
9
Hector so the vortech was made for a mtx why does that matter? Besides transmission longevity I don't understand that there would be a mounting issue. What specifically would prevent it from being used? Details? Thanks
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
CEG road warrior
CEG road warrior
The Vortech mounted specifically to the MTX.....I have an ATX. Totally different. The Vortech may fit the MTX Contour.....don't know for sure. If I had a MTX I would rather go with turbo anyway.
9
OK mounted specifically for the MTX, but the ATX and MTX motors are identical. Of course an ATX is totally different but you also have a contour and the supercharger was made for a focus which is also totally different. There must be a more detailed reason why. I am not doubting you but the reasoning so far is vauge. What would the fitment issues have been?
check out www.mondeoturbo.com thats a turboed mondeo zetec. also alot of focuses in USA have turboed (check out www.focaljet.com ) and alot of people in the UK have turboed zetecs in escorts, fiestas etc.
Originally posted by 96mercury:
for
to
97 Zetec MTX Sport Mk1 Mondeo Morettes & Clear corners Full SVT kit w/ Molded Mirko Splitter, Carbon Fibre Hood Ground Control coilovers w/ Koni adjustables, BAT anti roll bar Pics of my rides in my profile! Rally drivers do it sideways......
CEG road warrior
CEG road warrior
The engine is the same yes. The trans no. The Vortec bolts up to the TRANS.
So what do you think is better for the Zetec-ATX, Turbo or SC?
Moderated by  Loco4G63
