Page 3 of 6 1 2 3 4 5 6
Are there any kits for the focus (zetec) that use a centifugal supercharger instead of the traditional top mount with a modified intake? If there was enough room in the bay it would seem like a better option in that it is easier to install and after or intercool.
I know that the honda gang has been using a design that uses a shafted model in order to put the charger on the least crowded end of the engine bay for many years now.
Yes, this one uses the Vortech V9-F SQ supercharger.
Click here
98 Contour GL/03 ZX3 Focus/05 ZX3 SES Focus
good info. That truly looks like a clean install.
Locoz got a vortech for his zetec but said it wouldnt fit
i didnt really wanna spend 3000 - 4000 dollars thats why i went for the JRSC.
I know with the FS Vortech SC, you need to relocate the coolant resevoir and move some other parts around to make it fit. As you can see, it's a very tight fit to get the SC to fit on the belted side of the engine.
yeah it looks like its a squeeze. That's why I was curious to see if they had one that used a shaft driven by the crank and then extending to the driver's side where there is more space.
has ANY BODY JUST PUT A STRAIGHT UP TURBO SETUP ON THE ZETEC CONTOUR sorry damn caplock key
1996 zetec atx 19.3381 at 71.51 mph 1/4 mile click me for an interesting sitea wbsite you should check outjoined the 100k+ club 5/21/06
I was wondering if all turbos/superchargers are for mtx, because I'm stuck with a atx.
KJ
My ride(Cardomain link) : '95 Contour 16V Zetec DOHC, Teal , ATX Born on Sep. 4, 1995 86+ miles *LEDs mods are on their way!*
Well, it's the torque that most ATX's can't handle so the JRSC might be OK for an ATX since the TQ isn't increased that much. You get more HP than TQ with the JRSC.
But with turbo, the TQ might be bad for the ATX.
Is that because of the torc converter?
Moderated by  Loco4G63
