Posts: 3,732 |
i used zip ties for the rad
Russell
Oval Port 3L Nearly Done
Posts: 16 |
Well, tranny is out. Clutch looks like its burned to a crispy critter. Ash all over too. Not entirely sure how that happened. Gonna be fun putting back together. This is why I'm glad I sold it to my roommate before he let his gf drive it around everywhere. Worked perfectly before she got to it.
Life: Sexually transmitted and always fatal.
Posts: 21,197 |
Originally posted by Russell-3L: ya i forgot to add i use a cherry picker to support the engine, and yes you gotta remove the y-pipe!
No you don't.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 21,197 |
unbolt rack and pinion, i unbolted it from the subframe, and it was a PITA
No. Undo the "tri" bracket fot the steering under the dash on the floor. 1 bolt and it slides off. Pull out the rubber dust shield so it doesn't get hung up when the rack & pinion sides down with the subframe.
Also don't forget to unplug the VSS. Hard to see.
-'96 SE MTX 3L
Posts: 712 |
i undid the pinch bolt where the steering rack meets the steering column.
1998.5 Diamond White Pearl SVT (#4725)
custom exhaust/intake k&N/mod'ed y-pipe
slotted rotors/greenstuff pads/SS lines
cougar trans/FSVT shift tower/Torsen
16lb. flywheel
18" Velox VX-8's with some rubba bands
Posts: 451 |
just to let you know it is easy to get it out but putting it back in is a pain when you have to connect it to the torque converter in the bell housing i just put an engine in a probe so have fun.
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Posts: 21,197 |
The MTX is fairly heavy to reinstall alone. Life wih the legs/ Bet the ATX is terrible to maneuver around.
-'96 SE MTX 3L
