#1271225 05/08/05 12:01 AM
kamikos Offline OP
Sorry for calling you out specifically, but reading through the archives it looks like you're pretty much the forum expert on the 1-2 person transaxle removal/replacement in the garage. I was wondering if you could post step-by-step procedures of "your way".
Thanks
Life: Sexually transmitted and always fatal.
#1271226 05/08/05 01:35 AM
I've done it his way. I'm too intoxicated to do a write up tho...sorry for the tease.
#1271227 05/08/05 02:14 AM
Honesty....Gotta love it!
www.ChicagoCEG.com 2006 White Grand Prix
#1271228 05/08/05 05:48 PM
i can help here
put car on jackstands (on frame rail, not subframe)
disconenct and remove
battery
intake setup (pipe, tube, filter, airbox etc)
starter
axles - pop out lower balljoint. no need to take brakes or anything else off
unbolt rack and pinion, i unbolted it from the subframe, and it was a PITA
secure radiator with zip ties
disconnect wires going to the tranny
unbolt radiator, ac canister from subframe
drop subframe
put jack under tranny, remove bell housing bolts and toruque convertor bolts (if its an atx)
take tranny out
that easy
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#1271229 05/08/05 06:01 PM
kamikos Offline OP
Wouldn't you still need to support the engine from above? like with a hoist or bridge?
#1271230 05/08/05 07:10 PM
Yes, you need to support the engine from above. You will also have to support the radiator somehow. The radiator is held in with supports that bolt to the subframe.
You will also have to take the exhaust apart. Take the y-pipe and Cat out. You have to also undo the shift cables.
When you take the line off the clutch slave cylinder you need to have something there to catch the fluid. Over a day or two it will all leak out of the master cylinder.
It might be obvious, but got to say it - you should take the wheels off to get to everything.
You do also have to remove the sway bar ends from the shocks. The sway bar is connected to the subframe.
I found that the bolts that hold the steering rack to the frame are very tight and hard to get to. I un-did the hoses and pulled the rack out with the subframe. I might try undoing the rack and install it first this time. It is very hard to get very thing in place with the lines and all on the subframe.
The starter is on top of the tranny and will need to come out also. The starter wiring is a little tricky to get at.
Finally do not forget to unplug the speed sensor.
Good luck
1998 Contour SVT Black w/ Blue interior Torsen LSD updated shiftforks Lightened Flywheel, HD Drivelines Optimized Thottle Body 2003 3.0L engine upgrade (Soon to be)
#1271231 05/08/05 07:12 PM
I guess ignore the clutch stuff if you have an automatic.
#1271232 05/08/05 08:28 PM
i just pulled my trans myself in the garage... i followed the haynes manual and there is step by step on autozones web site.. i just looked at them both and used some common sense. you can iiiit!!
1998.5 Diamond White Pearl SVT (#4725) custom exhaust/intake k&N/mod'ed y-pipe slotted rotors/greenstuff pads/SS lines cougar trans/FSVT shift tower/Torsen 16lb. flywheel 18" Velox VX-8's with some rubba bands
#1271233 05/09/05 01:44 AM
ya i forgot to add i use a cherry picker to support the engine, and yes you gotta remove the y-pipe!
i was rushing out the door when i made that post
#1271234 05/09/05 01:47 AM
get some cotter pins to hold up the radiator up top in the engine bay. You can see the holes really easily, also the starter removal is a PITA I removed mine after the tranny was already out.
2000 svt #2103 of 2150 AEM short ram, B&M short shifter, no resonator 18" Enkei RS7's, 30% tint, C-27 front bumper
