I HAVE READ MANY POSTS ON TORQUE CONVERTERS AND TSS and Solenoid valves etc
My problem is all intermittent
After some hard drives I get the low speed "Bang Shift"
1 out of 10 hard drives
I get the 1744 about once per 10 drives
Is it the TSS or the solenoid valve?
GURUS please advise
1999 GREEN Contour SE SPORT Duratec V6, ATX, SUNROOF, 93,000 Miles, P0420 ON&OFF -replaced DS O2 --did not FIX *New TORQUE CONVERTER @ 53,000-Intermittent P1744 *New DASH at 53,000 and New DASH lifted-now using MOLLEY bolts to pull down
If you haven't replaced tss, I'd start with that. Also, install transgo shift correction kit from www.bulkpart.com
Bob
THANKS
The TSS looks easy to install using pictures in the threads
The Shift Correction kit listed for $30 was not described in the reference you gave. Any threads that I can review?
I need to see if that is in my capability
THANKS AGAIN
1744 TC slip is exactly that, the PCM calls for TC lock up (or some percentage of lock up) and the TC locks. The TSS and engine RPM are compared for the speed, gear ratio and percentage of lock up. Any deviation (slippage) is detected and after a set amount of time (with slippage) a code is set. I doubt that changing the TSS will correct your problem (1744) but for under $30 bucks and some swearing it can�t hurt.
Also be advised that if it is TC slippage you will need to replace the TC and reman the VB (with updates) to fix it.
A good scanner that can display engine RPM and TS speed would be helpful as well as a road test with a gauge connected to the TC tap.
jeff
have you fixed your ford lately?
U
U
I agree with Mercman and BT, but would also like to add this is a text book CD4E failure; due to a worn valve body.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
Could also be TPS and CPS.. Err?
Have you tried check the ATX fluid levels?
Maybe add a little Lucas.
My ATX rattles...Just a matter of time.
THANKS
This is my 2nd TC. First one a 30K
The problem is very intermittent
I drain [and replace] 4 quarts of Merkon 3 at every oil change [3000 miles]
If I drive near or over 80 MPH I get the 1744 hit more often
It takes 5 Hits to get 1744 as I have read in the THREADS
I like the car but this problem has got to me
Any info is greatly appreciated
THANKS AGAIN
You need to repair the bypass valve with an updated (modified design). Just changing the TC won�t fix it for long. A bad bypass valve is like ridding the clutch with a manual. You can do it but the clutch (TC in your case) won�t last long.
jeff
