Posts: 105 |
hi, i need to get a new head for my 1995 Contour SE... and i need to know howmuch work do i need to do to make the 3.0 head from taurus work, and what all the parts i need......thanks oh and howmuch faster would it make me?
Posts: 1,746 |
You do not want to put a 3.0 head on a 2.5.
Posts: 105 |
why not people do it all the time here??
Posts: 899 |
only if you already have a 3.0L installed. never put 3.0L parts on a 2.5L.
98 CSVT t-red
1737#
cf1 Cowl hood
Centerline Storms
CEG Dragon Run- Oct 13-15
WTB- Vortech S/C kit/ADC Turbo Kit
Posts: 4,693 |
The combustion chamber on the 3.0 is larger in diamer than the cylinder bore of the 2.5 so you would have a "mushroom" above the cylinder. I'm also sure that it would create cylinder sealing problems. The larger chamber volume of the 3.0 head would cause a significant drop in compression. The valves are bigger in the 3.0, as are the ports so you would at the very least need to use both heads from the 3.0 to stay in balance from one side to the other. The early 3.0 heads do not have a water pump drive on the back of the front head. The late 3.0 heads that do have the water pump drive have different port shape that is not compatable with the 2.5 intake manifolding without extensive rework if at all.
If that is not enough to make you rethink the project then I'm sure that someone more knowledgable than me will toss in their $.02 as well.
Basically, there is no real good reason to use the 3.0 head on a 2.5 and there would be a lot of things to overcome if you decide you want to do it anyway.
I'm sure that there are more reasons, but
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,746 |
Originally posted by 95ContourSE95: why not people do it all the time here??
No, actually they don't. I think everyone is in agreement that this is a bad idea for the reasons that Big Jim stated.
Posts: 7,100 |
You are thinking of 3L hybrids.. 2.5 heads in a 3..
Ray
'99 CSVT - Silver #222/276
Posts: 4,693 |
Maybe he misunderstood the 3.0 conversion and thought it was only the heads and not the entire engine.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 6,760 |
Holy Crap! A whole forum dedicated to the 3.0L? Who'da thunk?
Ryan
Trollin!
Posts: 21,197 |
This thread makes my head spin.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
