c150L Offline OP
So I had a broken spring on the the RH front strut of my 96 Contour, 2.0. I bought a set of springs and found a step by step "how to" for replacing struts. this procedure worked fairly well on removing the strut with broken spring. I now have the new spring on this strut but can not get the strut back into the steering knuckle. The lower control arm does not let the knuckle go low enough and /or I can not compress the spring stut enough to get the strut back into the hole in the steering knuckle. If the following link works for you, this is what I did to remove the strut. Otherwise, here's aC&P of the steps taken. (Skipped step one.)
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/d6/d9/0900823d801bd6d9.jsp
Disconnect the negative battery cable.
Raise and safely support the vehicle.
Remove the wheel and tire assembly.
Lower the vehicle enough to gain access to the strut retaining nut.
From inside the engine compartment, hold the strut piston with an 8mm Allen head wrench while removing the top retaining nut.
Disconnect the sway bar link from the strut.
Remove the brake hose and anti-lock wiring from the strut bracket.
Remove the steering knuckle-to-strut pinch bolt.
Work the strut out of the steering knuckle and lower the strut out of the strut tower.
Remove the strut/coil spring assembly from the vehicle.
c150L Offline OP
Never mind, I found another post with about 4 pages worth.
I should add one thing though. Try walking away from your dilemma if it is frustrating you. I went back down, used a 4' pry bar which seemed to give me 1/8-1/4", but being alone, it was more trouble than worth. So I tryed what I was doing again. Couldn't believe it when it went in rather easily. (I did say rather!) A little prying with 2 flat screwdrivers, twisting and pushing, etc, but far less that before I came up an posted.
This is really a great board. Even when it doesn't help, it does.
Dale
Dale
Been there.
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
When I was replacing struts I had the same problem. Some one, and I can not remember who, suggested clamping a 2X4 to the lower control arm to get more leverage when depressing the arm. Worked great and gave me a place to sit.
Rich S
1998 SVT 1995 Contour 2.5 MTX 215K miles Son's car(dead and buried) 1997 Contour 2.0 ATX 1998 Contour 2.5 ATX 2004 Tauras Wagon 3.0 Duratec
Flat pry bar, 2x4, et cetera.
It doesn't take much pressure to lower the LCA enough so the spindle pops right on.
