My A/C works fine and it blows cold air but I have noticed that the compressor is kicking in and out constantly. Is that normal, does the system have a leak, or what should I check for.
Same thing is happening on mine. I had it checked and pressure was really high. Guy thinks that there is a filter (I think) in a feeder hose that may be clogged.
1998.5 T-Red on Midnight Blue SVT
Build Number 5320 of 6535
Originally posted by Christian: Same thing is happening on mine. I had it checked and pressure was really high. Guy thinks that there is a filter (I think) in a feeder hose that may be clogged.
Thank you for your replies.
I will check for the R134 pressure and also for that filter. Do you know where exactly is this filter located?
