Page 3 of 3 1 2 3
#1271064 05/08/05 07:13 AM
Originally posted by Thinkmoto:
Originally posted by durateX:
Demon your car cannot look any cleaner. Do you think you will ever look into light racing 17s?
Bah Demon 17's you know deep down within he wants some 19's
you got pics of the suspension all painted up? I got half my suspension powdercoated it sure does look pretty
No way man. I'll be the first to run 24's. 24x1 with tires at 90psi. 100 spokes at least.
Yes I have looked into 17's a few times.
I'd want to pick up a rim that was in the 15-16lb range or less. REV makes a model (V IIRC) I really like and is very light but "OF COURSE" it's not drilled for our 4x108 pattern. Their REV X is pretty sharp looking.
Overall the selection in 4x108 really bites.
I don't like the "fancy shmancy" rims. I'm boring. Give me a nice 5 spoke with thin or flat spokes and I'm good.
I actually really like the stock rim. It's just a bit heavy for a 16 compared to most decent aftermarket rims. It's actually not bad weight-wise for a stock rim.
I'm still on the fence. I may just pop another set of rubber on the stock rims (IT NEEDS IT!) and wait to see if anything comes along. I plan to get Falken rubber either way. Size for size they are 3-5lbs lighter then a comparable tire from another manufacturer. That's crazy gains. It's not surprising considering they made race tires before they made street tires. The tread wear can't be any worse then the normal HP tire. (20-25k per set)
I painted the spindles, LCAs, & tie rods. Basically anything that had a chance to be seen behind the wheel. Also so the spindles don't rust.
I had painted it all before when I did the 3L (over 1.5 years ago now - DAMN does time fly)
Nothing fancy, I used silver just like the calipers, brackets, and rotors.
The struts are still black and say Bilstein and the springs are still red and say H&R.
#1271065 05/08/05 01:44 PM
CEG road warrior
CEG road warrior
Originally posted by mikey boy:
clean as hell.
And a sleeper.
Page 3 of 3 1 2 3
