Posts: 611 |
There are flasher versions or chip versions. The flasher tune was $50 cheaper last time I had it done but it is permanent unless you have the software. That may be a good thing though. It means you'll never have connection issues with the chip.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 862 |
Closest one is in WA other then a ford dealer which I will have to call. I would prefer the permanent tune over a chip. Thanks for the link I will see what the dealer says.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 862 |
Ok I moved the battery to the trunk using 2awg welding wire with pre fitted ends so it looks really heavy duty/clean. I also installed a vac/boost gauge.
Posts: 862 |
Exhaust manifold has been finished. Now it is a direct bolt on between the head and turbo. The exhaust points in the right direction too  I am thinking the modified factory focus manifold should flow better then a log style turbo manifold. I welded all of the exterior head flange to header pipe joints to add some strength and seriously reinforced the area between the turbo flange and head flange so that I don't have to worry about having enough support to hold the turbo. I ordered a new turbo center section because even with new bearings my turbo still has a lot of side to side play so the journals are just too worn out. I have 6 different silicone couplings now all straight pieces some that adapt different pipe sized and I picked up some intercooler piping from a few volvos. One piece is a perfect fit to hold the IAT sensor and elbow into the throttle body.
Posts: 1,224 |
Originally posted by 96mercury: I am thinking the modified factory focus manifold should flow better then a log style turbo manifold.
I'm thinking that as well. If the stock one doesn't flow that great, you could always mod one of the aftermarket Focus shorty headers.
Dang dude you are moving fast. I'm back to saving more money before my turbo project can continue.
I can't wait to see your system up and running.
Later, Ben
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 862 |
OK I installed the oil catch can/seperator using the same method that SLeeperz did and it looks really good. Thanks again for the how-to on that sleeperz  I also installed the PCV for a 88 thunderbird turbo 2.3. I bought it from the dealer because all of the aftermarket ones would blow both ways while the factory one acted like a one wya valve which should prevent/reduce boost from entering the crank case. I ordered one step colder copper plugs from the dealer today only $4 a piece. I think I need to set them at .040 for the turbo? Any recommendations on oil? I used Mobil one tri-synthetic on my turbo neon and it seamed to work the best. I am going to get a guy from school to re-work the end tanks on my intercooler so that they point in the right direction to reduce the need for multiple bends.
Posts: 495 |
I use mobile i synthetic, not sure if it's tri-synth or whatever, 5w-30. I have mine gapped around .04, but it depends on how much boost and if your ignition is weak. I had them down to .030 under nitrous and there were still a few misfires. At least .045 and see how it goes.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 862 |
Seawulf thanks  So my coil is practically new with only 9k miles on it now think I should be ok with .04? Also correct me if I am wrong but the smaller the gap the the colder then plug is in a way correct? Also too small of a gap and the plug won't fire becasue the flame will get snuffed out? Thanks.
Posts: 495 |
No, too small a gap won't cause a misfire I think. My gap at .30 was misfiring because it was still too wide and the cylinder pressure and fuel mix was still blowing out the spark at a few spots in the rev band. I was running a fuel mix of high 10s. I heard of one Focus needing a gap 0f .025 at around 200whp cause it's coil was weak. I don't know about that smaller equals colder.
Posts: 8,143 |
I thought a smaller gap was to avoid spark blowout, which is more prone to larger gapped plugs?
